Maertz's Half Ass Build Thread
#241
ell coilovers are ordered up. Decided to just got 16" front/rear to keep it simple. Looks like 18" may have worked, but i didn't want to chance it and in all reality 16 is plenty...
Tonight should be finishing all rear frame mounts. Front/Rear Bumper and filling the big hole in the rear.
#244
Thanks man. Its slowly getting there. Should be driveable a day or 2 after i get the shocks is the plan, but will still be a month or 2 till i can call it mainly done. The tires will cost a bit.. Once i sell my old tires or rear axle i should be able to have the axles fully built.
#245
Well one side damn near fully welded on.
Also got the rear plate in to go over the hole I cut, but sorry I didnt take a pic of it and tank is already installed over it so I dont feel like taking it off just for a picture...
Working on making sure the axle is perfectly centered front to rear and side to side. The arms are set to the same length and once this is all done I will raise up the lower link crossmember and get it tacked in. There will be a lot of gusseting in my near future.
Once thats fully welded in I will be taking those jack stands to start working on the front. Hoping that over the weekend I get that done and the rear at least set under there.
Also the last crossmember I was hitting is 90% out... I had a plan to do a few things and as the night progressed I noticed my self working on completely different stuff than I had planned....
#246
Well lots of little stuff done today..
Welded plate onto frame rail to make it level for crossmember. Also measured up where it all needs to be so the rear axle is exactly centered.
Got the driveshaft close to where it needs to be.
Got the front axle set under there for now. Need to get it on jacks after the rear is burnt in.
Just measuring here I got 114" wheelbase, it was at a slight angle, but I also moved it forward another inch. Im guessing between 112" and 114"? But still to early to tell.
#247
Well played with steering a bit today, and cut our the fairlead hole.
Had my first set back.. I for some reason ordered angled lower mounts, wich I do not need. So i will have to wait on them to get them in and mock up the arms. Also had one rod end I assumed was the same as the jk wich it is not for my steering. I was able to mock it up with a smaller bolt, but need the correct one.
#249
