Maertz's Half Ass Build Thread
#511
I guess I'm the asshole that uses a stack of harbor freight cut off wheels on every project. They work well, as long as you get a round one
They do like to explode though...
#512
Lol i luck out i sell a broad line of stuff and have access to pretty much anything id want to try.. Except Harbor frieght
#513
Well battery mount painted and installed and yellowtop is also installed...possibly will try and start tomorrow again.
Got front and rear d rings tacked on...
Extended my wheel speed sensor wires still need to make a mount..
Got the rockwell shock mounts tacked together...
Got all my fittings for my ram, but need to make a mount...
Thought up a good idea for my spare tire carrier i want to build in the future.
Also made a list of stuff to do for the next few days
Not great for a few hours of work but tomorrow and sunday im hoping to get alot done. I need tro try and stick to my list and knock some out instead of getting sidetracked and debating ideas for other stuff..
#514
Well 3m came out with some new cutting discs and they last a lot longer then the walter and cheap discs. Thats all my second employment uses. Walter and 3m. And most of the welders were amazed at how long the 3m cutting discs lasted. ( way more money too ) haha. Man your jeep is looking good. Cant wait to see it rolling.
#515
Well battery mount in
Then flooded my cylinders so bad my intake also was filled up... Had to blow out cylinders after pulling all plugs. Also had to test injectors and take the top part of the motor apart to get at the fuel rail... Got that almost put back together..
Also got my fuel system all set up properly finally...
Kind of a pain in t he ass set back....
#516
Well its finally running... I wot go into details ill just say im an idiot... But on a good note its running. Fuel pumps pretty loud...
Got a few dash lights to slowly work on now as well as get the rear gears done so I can drive it.
http://youtu.be/XHjbXuqKVMo
#519
This is just on 37s that measure 35", my other tires and rims should be here by the weekend... Still tons of cosmetics to do and lots of little stuff.
Walk Thur As it Sits on 8/3/14 - YouTube
#520
Ha thanks man its been a wasted 2 weeks due to my stupidity... I should have been driving and had some small testing done, maybe even some cosmetics.. But you live and learn, in all reality im surprised i didnt have ore set backs being my first big build.
