Maertz's Half Ass Build Thread
Old 11-21-2014, 05:47 PM
  #621
pjmjk's Avatar
Originally Posted by awinski
i figured for a while one jeep related forum was enough for me. why can't there just be one. it would be sooo much simpler
So very true
Old 11-23-2014, 02:32 PM
  #622
Maertz's Avatar
Well first official trail run so far. It held up with no problems yet. People were not wrong mounting the coilovers to my roll cage is definitely loud. The coil noise seems to be amplified throughout the cage so far...
Not many pics, but even in the wash it seemed alot more stable and able to handle the woops. Still need to adjust front bumps and do a ton of cosmetics. Need to finish that front axle not having 4 wheel drive sucks....
Old 11-23-2014, 03:12 PM
  #623
awinski's Avatar
looking at both of your threads at the same time #magic
Old 11-23-2014, 08:46 PM
  #624
Descent's Avatar
Not many pics, but even in the wash it seemed alot more stable and able to handle the woops. Still need to adjust front bumps and do a ton of cosmetics. Need to finish that front axle not having 4 wheel drive sucks....[/QUOTE]
Tunning the dual rate stops down really helps a lot too, if you havent already played with them
Old 11-24-2014, 03:18 PM
  #625
Maertz's Avatar
Yeah i noticed that mine was not on right i need to adjust mine... Also need to adjust my front bumps. Those 2 alone will make a big difference.
Old 11-24-2014, 03:44 PM
  #626
Maertz's Avatar
Well looks like ill be needing to go a little stiffer on my upper spring up front its damn near collapsed at ride height. may try a 200 over 300
The rear looks better. Still kind of wish i would have done 18" lol
Old 11-24-2014, 05:11 PM
  #627
briaros6's Avatar
Looks really good so far, I know my coilover rates are 250/350 and it's decent on road but in the dirt is a nice comfortable ride although the desire for some suspension seats is creeping higher and higher on the priority list...
Old 11-24-2014, 05:26 PM
  #628
Maertz's Avatar
Yours are same front to rear? My rear end is a ton lighter but i dont have a spare or carrier yet.. But the front also doesnt have my winch installed.
Old 11-26-2014, 08:35 AM
  #629
briaros6's Avatar
Yes, I'm not running a very heavy front bumper and winch combo and I'm also not running a rear bumper (which makes up for the heavy ass Nitto hanging out back) at all so my weight load isn't very much from stock. It'll be interesting when I do start adding armor though...
Old 11-26-2014, 09:36 AM
  #630
Maertz's Avatar
Well got the forklift test out of the way... Overall not bad... Could not max the front out though as my bumps in front and rear are off. I figured they would be but they are all heavily tacked on as i plan to redo them for the next tires anyway as these run small. Still happy the front shocks clear the frame by about a 1/2 inch so even at full flex they should not get into the frame. Front tire got around 4 feet and the rear was around 5 feet. I will measure better once i get all my bumps and such dialed in.
