Maertz's Half Ass Build Thread
#632
The rear id say about 1500 max and itd be less if i got one that didnt need spindles to fit 35 spline... Could also go 14b for under a grand i bet.
The front will be around 2800 based off my math and depending if i go air locker or detroit.. I dont have everything yet but thats what its looking like.
Lol tires and rims will almost be more than the axles...
#633
Thanks, I'll need new tires by the spring, I've been debating buying a 60/14b combo and throwing the artec bracket kits on them. Guess I'll have to start looking around again for a local set.
#636
Well heres my current slow moving todo list... Thoughts?
Move Rear Seat 1"ish Forward
ESP Bracket
Make Badass/Removable/Fold Down Spare Carrier
Maybe Epic Rack Also?
Bleed Brakes More
Redo Fuel System
Cap Frame Ends
Retain Front Grill
Fix Wheel Speed Sensor Wires
Measure For Skids
Tie Body To Frame
Swap Coil Rates
Adjust Bumps
Trim Front Frame
Finish Front Armor
Tie Shock Hoops Together
Tie Link Brackets To Frame More
Fix Paint/Bedline?
Build Front Axle/Driveline... $$$
New Tires/Weld on Beadlocks $$$
Enclose Rear Shock Area
Finish Cage
Tube Fenders to Frame/Body?
Exhaust System Install
Redo Air Tank Gauge
Trim Front Wheel Well?
Fill Cage With Foam Where Possible?
Pretend I Offroad and Join WAL.
ESP Bracket
Bleed Brakes More
Redo Fuel System
Cap Frame Ends
Retain Front Grill
Measure For Skids
Tie Body To Frame
Swap Coil Rates
Adjust Bumps
Trim Front Frame
Finish Front Armor
Fix Paint/Bedline?
Finish Cage
Redo Air Tank Gauge
#639
Well heres my current slow moving todo list... Thoughts? Move Rear Seat 1"ish Forward ESP Bracket Make Badass/Removable/Fold Down Spare Carrier Maybe Epic Rack Also? Bleed Brakes More Redo Fuel System Cap Frame Ends Retain Front Grill Fix Wheel Speed Sensor Wires Measure For Skids Tie Body To Frame Swap Coil Rates Adjust Bumps Trim Front Frame Finish Front Armor Tie Shock Hoops Together Tie Link Brackets To Frame More Fix Paint/Bedline? Build Front Axle/Driveline... $$$ New Tires/Weld on Beadlocks $$$ Enclose Rear Shock Area Finish Cage Tube Fenders to Frame/Body? Exhaust System Install Redo Air Tank Gauge Trim Front Wheel Well? Fill Cage With Foam Where Possible? Pretend I Offroad and Join WAL.
Laughing my ass off!!
#640
