My front bumper build - comments please
Old 03-07-2010, 09:01 AM
alancamby's Avatar
looks great
What thickness of steel are you using? Make sure that the winch plate is plenty thick. I would use 1/4" for this part.
What size hole are you using for the shakle mounts?
Do you have a Rubicon? Make sure you leave clearance for disco motor.
Here is the mounting template I made when I was working on my front bumper. Note that the top holes are spaced further than the bottom.
Good luck.
Old 03-07-2010, 09:09 AM
alancamby's Avatar
Originally Posted by noot
I have a request: Can someone measure the "depth" of their aftermarket bumper and tell me? I need "front of bumper" to "grill" distance... just to compare to see if mine it too deep.
This is my homemade bumper depth. That measurement is 7 9/16" ( Picture looks less than that)
Old 03-07-2010, 01:09 PM
o7jk's Avatar
nice design. I wish i had the skills/tools/ CAD ability to do something like this. Post up picks when it's on you JK
Old 03-07-2010, 01:41 PM
noot's Avatar
Originally Posted by alancamby
looks great
Good luck.
Thanks for the Q's. I think I've got them all answered.
Planning on using 3/16" for everything, with the exception of the shackle mounts. I've thought about making the front (where the winch mounts) 1/4", but this would significantly increase the weight. I've talked to a few people that say 3/16" is enough, but that's definitely debatable.
Shackle mount holes are 1.1", mounts will be made from 1" steel plate.
I do have a rubicon. The bottom of the bumper is only 3.5" 'deep', so there's plenty of room for the disco. I do plan on adding a skidplate that goes from the bumper to the cross-member, and further back, but that's step 2.
Below is my mount w/ measurements (it's the driver side mount, looking at the jeep from the front). A few small differences from yours.
I'm making 0.6" holes, except for the top-outer hole, which will be .5" (as per the jeep's mount).
My original hand-drawn measurements have more info... specifically that none of the holes are "square". The bottom holes aren't horizontally-aligned, the inner holes aren't vertically-aligned. The inner-bottom hole (bottom left in my drawing) is up and in relative to the other holes. This is visible in my drawing.
How bang-on were your holes? What diameter did you drill them?
Thanks for the posts
Old 03-07-2010, 01:53 PM
noot's Avatar
I'm sure you do. I don't own a single metal-working tool. I know a few guys with welders and experience, and I started playing around with Solidworks in order to do this with no prior experience.
That said, we'll see how the end product turns out
Old 03-07-2010, 04:20 PM
alancamby's Avatar
What worry's me about using 3/16'' on the winch mount is the absents of bends or reinforcement in your front plate. If the top (section with Noot on it) was bent back at a 90 degree angle it would give it a lot more streath. I am sure that a lot of winch plate manufactures use 3/16", but the design has bends and reinforcements. Just my opinion, I am in no way a engineer. You will probably be fine.
I can't remember what size I drilled my bumper holes
It has been a long time since I made my bumper. I know that I used 7/16"-14 bolts for the 8 holes. Mine has a 3/4" plate bolted to each frame horn faceplate. then the bumper bolts to the plate with a total of 4, 1/2"-13 bolts. Sounds heavy, but there is very little 3/4" plate in the design.
https://www.jk-forum.com/forums/jk-show-tell-33/homemade-front-bumper-119686/
I think your bumper is going to look great when it is finished.
Old 03-07-2010, 07:24 PM
noot's Avatar
I just toyed around with "Beam Stress" equations. Using the elasticity of steel and a bunch of other "think I got it right" numbers, it looks like with 16000lbs of force, that front plate will deflect only 0.0005", which is like... nothing.
I think I'll risk using 3/16", I'll see what happens There isn't a lot of abrupt tugging action on a winch, so really the most force it'll see is the capacity of the winch... 8000lbs, and even that's pushing it. The shackle-mounts would see a lot more, but it looks like 3/16" is good enough for that too, as almost every aftermarket bumper is 3/16".
Worst case, I get to go Round 2 on front bumper design
I do appreciate the input.
Old 03-08-2010, 08:24 AM
Ice
Ice's Avatar
looks really good!
Old 03-21-2010, 12:18 PM
leman's Avatar
cant wait to see this done. my 8274 has been sitting in my shop waiting to go on the jeep
Old 03-23-2010, 06:13 AM
noot's Avatar
Default Almost done
My buddy and I have been working on it this past week. It's almost done... I'll wait till it's done to post everything up but here's a sneek peak:
Quick Reply: My front bumper build - comments please
