Nemesis, MCE Flat Flares & Dirt (Photo request)
So Ive been searching and thinking on a swap out from stock flares to either Nemesis or MCE Flat Flares.
I really like the design of the Nemesis flares.
I was wondering how either flare are at holding the dirt off the side of the Jeep. Ive read about the bushwacker flares not really keeping dirt/mud/slush off the sides. The stock doesnt seem to really do much better either but Iver heard the flat flares are worse.
Im looking for pictures or information to see how much dirt gets on the side of the jeep before I went out and bought/installed them.
I know alot depends on the BS of the wheels as well as the width of the flare. So Looking for the Odyssey since I heard they are the widest Nemesis make.
Im running the Mamba M1RX wheels 16x8. I believe the BS is 4.75" I was thinking of running a 35" tire (currently running a 285/75/16 tire) but not sure what the minimal width is without the pizza cutter look. I didnt want to run 12.5" wide either.
I wanted to do a 35" no lift set up.
Also if you can give me a coverage measurement of each flare (Nemesis or MCE)
So far it looks like the Nemesis are out of the question. I wont pass inspection here in PA.
What size tires ya running Rostr02?
Any MCE flares out there???
33, and yeah you can just swap the stock tires on and I'm sticking out because of the offset of the wheels. If you are running stock wheels and a spacer just pull the spacer and go get it inspected. I just got mine inspected with the stock wheels on, I'm in Pittsburgh
nemesis also makes wider flare option if it is coverage you are worried about.
twoxstreem Do you have ace liners in the front and rear? I wasnt aware of aftermarket liners. I did read you can use the fronts that came with the Jeep. Can ya share some part #'s if you have any?
