no lift on 35's
Official no lift/1" or less lift on 35's Thread
Requirements:
-Your lift can't exceed 1"
-Flares, no flares, tube fenders, cut flares doesn't matter.
-We're lookin for pics and experiences you've had w/ your fenders/flares.
-It's ok if you no longer run this way anymore.
Let's see em.
Let's see em.
You WILL rub on the rear body with 35s. Mine was like below for short time, it was fine when alone, but it did rub with buddies aboard, and rubbed with axle articulation.
Also my (supposed) 35" MTZs only measure 33.75" diameter at 29psi, so I got away better than many other (supposed) 35" Mud tires (which in reality measure 34-35").
no lift, no fender chop
no lift, with fender chop
I'm still runnin' 35s, but only had them on for day with the stock flares before slapping on some xenons. I've got a set of 0.75" spacer that are going on when I get back from deployment. All of my pics are in the gallery (stock, 35s, flares, etc).
Perfect, I'd like to make this an official no lift or lift under 1" thread as I'll be removing the flares on mine and cutting the fenders up slightly.
I'm in high hopes that rev111 now known as metal cloak will come out with some arched tube fenders.
or I may get some OKE tube fenders. (overkill engineering)
