Poison Spyder Brawler lite bumper & skid install
I know this is old thread back from the dead. Doing same tomorrow. Couple quick questions.
1. Can you mount lights after bumper install or died it need to be done first.
2. Part of the light bracket is silver. Can that be seen once lights are installed?
3. I was reading people were installing a diode for flaming of fogs. Not clear what ohm and on what line. Neg or pos and do you put diode in line before or after the light harness.
4. Can the stock fog light switch handle the fogs and is there away around to rigging it so fogs won't turn off with brights?
5. Mounting winch as well. It appears I can do that after bumper install correct?
Thanks in advance.
Thanks in advance.
I know this is old thread back from the dead. Doing same tomorrow. Couple quick questions. 1. Can you mount lights after bumper install or died it need to be done first. 2. Part of the light bracket is silver. Can that be seen once lights are installed? 3. I was reading people were installing a diode for flaming of fogs. Not clear what ohm and on what line. Neg or pos and do you put diode in line before or after the light harness. 4. Can the stock fog light switch handle the fogs and is there away around to rigging it so fogs won't turn off with brights? 5. Mounting winch as well. It appears I can do that after bumper install correct? Thanks in advance.
1.the bumper has to be off especially if you have the skid plate
2.No
3. That I don't know
4. It can theres a write up somewhere, but imo it would've been easier my route. But to each his own.
5. That I don't know
Good luck.
Anyone have ideas as to not cut or grind the crash bar to install the skid plate? I don't want to hinder the crash bar at all for warranty and insurance reasons. I was thinking of putting a spacer piece of metal in between bumper and skid plate to get my clearance.
Any thoughts? Thanks guys
I have the poison spyder brawler mid with the matching skid with it. I didn't have to remove the crash bar. I think I may have had to trim the lower corners, wasn't much. easily done with a grinder.
