Show me 33's with/without lift, BB, and spacer lift
Old 03-18-2014, 05:29 PM
Gforce!'s Avatar
Location: Independence and Lexington, KY (depends on the time of year)
No lift needed for 33s. Full stuff no swaybars, no rub. No lift is better to keep ride quality for a DD, especially since you aren't getting much bigger tires.
ID:	538702   Click image for larger version
Old 03-18-2014, 06:06 PM
ljvsnyder's Avatar
285/75-16 falken rockey mountain ats II no lift and stock steel wheels no rubbing on road.
Sent from my SCH-I545 using Tapatalk
Old 03-18-2014, 06:12 PM
Jon85's Avatar
285/75/16 toyo at2 with 18/59 spring swap
Old 03-18-2014, 10:11 PM
Surinam's Avatar
285's, no lift, cut fenders
Old 03-19-2014, 01:14 AM
catahoula's Avatar
Your ride should stay the same if you were to install a spacer kit.
A BB would have more components than a spacer/leveling lift.
Old 03-19-2014, 05:57 PM
ShutterBug's Avatar
33" no lift.
Old 08-04-2014, 09:48 PM
IamMark's Avatar
Run the same tires & wheels for over a year with no lift & factory flares. They only rub the swaybar a lil at full steer & still do, never touched anywhere else. 3"front, 2" rear BB lift now. 33X13.5X17 with 4.5" back spacing, no wheel spacers
ID:	569513   Click image for larger version
Old 08-05-2014, 04:56 PM
chris h.'s Avatar
285/70/17 with Daystar 3/4" front level spacers, added washers to steering stops to prevent rubbing.
Old 08-05-2014, 05:23 PM
woodyvw9's Avatar
2.5 TF BB, 295/70/17 Trail Grapplers.
ID:	569715 Click image for larger version
ID:	569713 Click image for larger version
Old 08-05-2014, 10:09 PM
mr70ss's Avatar
Here is a before and after of mine. Toyo AT2 xtreme on procomp 7032 wheels. Slight rub on front sway bar at full lock. No lift yet, plan on installing a TF leveling kit this weekend.
ID:	569748Click image for larger version
Quick Reply: Show me 33's with/without lift, BB, and spacer lift
