Show Your "whoops" Stuck Pix
Well, it finally happened...I got stuck for the first time...I am proud to say "at least it took a F-250 to pull me out!"....don't be shy...."STUCK happens!!"
I got about 10 ft. into this muck and there was a drop off....whoops...least i had tha balls to try....
ok this would be the 3rd or 4th attempt. at the top the ruts went straight up and i kept high centering. it took 2 jeeps fully locked to pull me over! i was stuck! this was the only way out as you can see behind me was a frozen lake (large pond).
I got a couple, the first was when I was offroading at night and alone which was a bad idea because I almost when over this cliff. And the second one was when I dug myself in up to the frame driving through a swamp.
