Waldo's 1 Ton Build Thread
Alright, finally have some time off tomorrow! I am hoping to get the old axles out, the new ones mocked up, and the trusses welded on. Pictures to come!!
The rear is in!! The brakes on the 10.5 were ran off one line that split at a T to each rear caliper. I need to figure out how that will work and it'll be on to the front!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=609580"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=609579"/>
I'm an idiot.. With a little help from the grinder they work just fine.
I "flexed" the rear end I found that the corner of the fuel tank is going to contact the axle quite a bit. Does anyone know if a 2 door tank would work, or am I looking at a fuel cell for an answer?
I have heard that the 2door tank works. Check out invest or maertz build. Invest I believe is going custom but I have heard that the two door tank does work but obviously the down side is less capacity
