JKS JSPEC 2" Lift
JKS JSPEC 2" Lift
I've got a bigger lift on its way to me so I'll be pulling off this lift in the next few days:
JKS JSPEC 2" spring coils (set of 4)
front sway bar links
front and rear shock extensions (for use with stock shocks if needed)
If you are looking for a "budget boost" or small lift, this is a great option. I've run this on various trails throughout California and also use this as a DD. Has performed great on both trail and pavement.
Here are shots with 33's and 35's:
Asking $300
(shipped on your dime if can't pick up from Central California)
Asking $300
Now Available
OK, it took a little longer than I thought but the lift is now available for purchase. This includes the 4 springs and extended sway bar links.
Forget the "budget boost" kits, this is a REAL lift that will actually perform better on the trails while giving you the room to fit bigger tires. $300 takes this home!
