2007 Wrangler X 2 Door Leaking Top
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Mar 2009
    Location
    Houston, TX
    Posts
    18
    Default 2007 Wrangler X 2 Door Leaking Top
    Anyone one of YUZ out there have a problem with your top leaking?? Right at the windshield and the top of the door? Drips down on the door handle and then splatters all of the seat and floorboard??? Wondering if its just the 07's that does it...
  2. #2
    Join Date
    Jul 2007
    Posts
    1,535
    No it's pretty much every JK. Polls here indicate 1 in 2 is defective. Occurs pretty consistently from the 07 to 09 models. Generally, repair attempts make it much worse.
  3. #3
    Join Date
    Mar 2009
    Location
    Houston, TX
    Posts
    18
    Good to hear... My brother n law and I got a roll of some of that "faomy" tape [not duble sided] and stuck a good amount on the part where the top meets the Jeep. It held for about................................... a day... LOL!! Thanks for the feed back. Thats why I got the Quadratec mats and they keep the water from getting to the carpet. Sure can stink up the Jeep in the hot humid summers here!!
  4. #4
    Join Date
    Jul 2007
    Posts
    1,535
    I removed the carpet the first week I had it. I like to run like that anyway. I plan on getting some nice seat covers and dealing with it. I might try out that Mopar rubber floor liner.
  5. #5
    JK Enthusiast eurojk's Avatar
    Join Date
    Dec 2007
    Location
    CHAVANNES DES BOIS, SWITZERLAND
    Posts
    258
    Mine was bad so took it to the dealer and they said I was not closing the top correctly and advised to put silicon on all the rubber parts at least twice a year. Since taking there it has not leaked but I have not removed the top yet so don't know if it will start leaking again after I do.
  6. #6
    Join Date
    Dec 2008
    Location
    New France
    Posts
    2,540
    Same problem for me. That's why I sold my Mopar soft top last Summer, and I bought the Bestop Supertop; not perfect, but much better concerning water leaking.
    The problem is the position of the sport bars. You can adjust the sport bars to put them closer to the door gaskets. Same thing for the windshield. I wanted to make a write-up, but I'm not good enough in English...
  7. #7
    Join Date
    Dec 2007
    Location
    Posts
    258
    Quote Originally Posted by JK Freedom View Post
    Do it in French then, come sa je peux régler le problème une fois pour tout.
    Salutation
  8. #8
    JK Super Freak Mariner's Avatar
    Join Date
    Apr 2008
    Location
    East Coast
    Posts
    1,588
    windshield is probably a tad out of adjustment, mine leaked when i got it, hasn't leaked now for a year.
    Loosen widshield bolts, leave doors open, loosen bolts above headrestsand pull windshield back, it won't go far but it was enough to tighten up the seal.
    good luck.
    2012 Bright White Rubicon Unlimited
    Born May 8th 2012
  9. #9
    JK Enthusiast joearod524's Avatar
    Join Date
    Mar 2009
    Location
    Hill AFB, UT
    Posts
    230
    I just got my used '07 2 door w/ a soft top about two weeks ago. It rained for the first week and I didn't have any leaks. Then the sun came out for a few days so I played with the top. Last night I noticed the same leaks that are mentioned here. I just thought I didn't put the top back up correctly. There has to be something that kept it from leaking when I first got it.
  10. #10
    JK Super Freak berg's Avatar
    Join Date
    Apr 2007
    Location
    Deptford NJ
    Posts
    1,121
    My '07 was dry until last week. Only leaks when sitting still.
    I'll fiddle around with it when the weather is warmer.
    I'm used to leaks.
    Had a sunroof in my old dodge truck. Leak
    96 Ford Taurus. Trunk leak
    Had a new Ford Escort in '82. Leak at front of door.
    Drove a Chevy 3500 company truck. Leak at windshield
    Glad I don't own a boat.
    Berg
    2007 Steel Blue X, 2 door, Soft top, Auto
    Rugged Ridge mirror kit,
    Rugged Ridge side armor
    G.E.A.R seat covers with AMC Jeep logos
    Drilled factory mirrors
    Dean Wildcat EXT M/T tires
    8" Shorty antenna
    Retro "Jeep 4 Wheel Drive" decals
    NJJA member
    www.northridge4x4.com (come on freebies!)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
