2016 Jeep Wrangler to lose the solid axles to reduce weight
#21
Ball joints
Trackbar
Bolt kit
Draglink
Different tires
Alignment multiple times, once by dealer, once by 4x4 shop
I also torque EVERYTHING during oil change
I also have a Honda Pilot with 170k, original struts, third set of tires..... never felt unsafe
#22
Seriously: Why not just go get a Grand Cherokee if you want IFS so bad? It's a really great vehicle. Seriously. Why do folks like you want to change something with the storied history and capability of a real Jeep, instead of just buying other quite excellent products that are available? I don't get it.
#23
I hear Toyota is stopping production of the FJ at the end of the 2014 cycle. Why would you want an FJ over a JK? I contemplated the FJ as a replacement for my TJ, but the JK aftermarket & great quality of the Wrangler brought me right back on track with a 2014 JK.
#24
Rubicon = straight axles
Sport = IFS
BTW: this is the only issue that I am not old school
#25
I'm sure I will never hear the end of this but, look at what happened with Hummer. They were known for their axles on the H1's and that's why they had to create an H2. They were under legal obligation to NOT change their solid axles. Solid axles have a documented history of be tough. Throwing those out the window to save weight is not the answer. A diesel engine would go a long way help with mpg's. Look at the aerodynamics of our JK's, they're flying bricks! Change the design a little and slap in a diesel and problem almost solved. When you realistically look at IFS vs solid axle how much weight are you really saving? Not enough to make enough of a difference.
#26
The design of the JK is susceptible to DW, and the lack of accurate tolerances worsens that. However, it's exacerbated by people who don't take the effort to get it fixed and continue to cause further damage that can cause DW in new ways that would have NEVER occurred on a stock vehicle.
#27
It isn't a matter of luck. I've installed/helped install at least a dozen lifts of various JKs. The only time--ONLY TIME--I had the vehicle suffer death wobble was one with DW before we started the lift, and the owner hoped a new 4" lift would "solve" his DW. He never fixed all of the consequent damage that had occurred through months of driving it, and would eventually sell it, DW and all.
You say yourself that "The design of the JK is susceptible to DW", when dialed in there is no problem.... one pothole and when you least expect it...... DW. How is that acceptable? There is no room for error. IFS has more room for error. If Jeep can't make straight axle safe then they should switch to IFS. Must my opinion...
#29
The family loves my Jeep but anytime we go hwy, we take the Honda. That is why the Honda has 170K and my Jeep only has 60k.
#30
The argument is not valid due to the fact it is based on opinion. I feel completely safe in my jk. It is safe to ME. I would think that the fact a solid axle vehicle rides as smooth as mine does is a small engineering miracle. Losing my off road capabilities to appease your fear is not a win for me, only for you. Show some facts as to where the DW is rampant and a change is warranted then you may have an argument. Seeing as how they sell every "death trap" they make I think the public does not share your fear.
