35" Tire Question
Old 10-28-2014, 01:18 PM
Mark Doiron's Avatar
Originally Posted by ade
You won't need to do anything with the pinch seams. That is a horizontal clearance issue not vertical travel.
My Jeep with 35s (Duratracs) rubbed on the pinch seams. It did this while aired down , fully loaded, and hitting dips and bumps at moderate speeds on White Rim Trail. The standard static demo on jackstands is not a reliable indicator since it ignores the effect of the aired-down tire bulging out. It is a good idea to trim the rear pinch seams for 35s.
Old 10-28-2014, 08:44 PM
ade
ade's Avatar
I'm running Nittos and and the tires clear by a minimum of 3/4" at full flex. They measure 34 1/4" actual. Don't see how airing down can increase radial diameter, unless you are fully compressed with the tire on a large rock right next to the pinch seam.
Old 10-29-2014, 01:09 AM
Okay, the full story since I'm on a computer and not my phone now. After I added 35s, I trimmed the pinch seam. I wasn't sure how far to trim it, so didn't dig too deep into the sheetmetal. Then, after trimming, I painted it with touch up paint. I then went on White Rim Trail--as I wrote, fully loaded. I didn't weigh my Jeep at that time, but I did just a couple weeks ago. My Jeep currently runs 6800 pounds, and that's not quite fully loaded--I was returning from a trip, so the jerry cans had been emptied, and we were running low on water and other supplies. I digress. Anyway, tire pressure reduced to 15 PSI (I now use 20 PSI, but that's a different story) on WRT. Whenever I'd hit a dip or bump I'd hear rubbing. This is what I found ...
Name:	Pinch Seam Damage to Jeep, Jun 11, 6684.jpg
The paint, which had been applied only a few weeks earlier, was rubbed completely away. I got out the tools when back home and trimmed it some more and have never had that problem again. So, my real world experience on the "you don't need to trim for 35s" says it just ain't so. You do need to trim--at least on the earlier models (I've read that Jeep has modified it so trimming may not be necessary on the latest models).
Old 10-29-2014, 05:47 AM
larry0071's Avatar
The 2014+ is cut at a 45 from the factory.
Old 10-29-2014, 10:55 AM
Old 10-29-2014, 02:43 PM
ade
ade's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=582043"/>
As I said before. I'm running 35" Nittos on an 2008 and air down to between 16-18 PSI on the trail and have never rubbed the pinch seam. So real world now says you may or may not require pinch seam trimming. 2500lbs over curb, what you carrying in the back sir??
Old 10-29-2014, 04:07 PM
A lot. A lot lot. But not when it rubbed because gear was at campsite and had soft top on. However had five people--my daughter's family, two USAF members, a gymnast, and her skinny brother, so please don't jump to incorrect conclusions on their weight. All four of them are not particularly large.
It is such an easy thing to trim to avoid the issue, I have no idea why people argue over it. Trim. Don't trim. The only thing I'm calling BS on is when people write it can't rub. Yes.It.Can.
Old 10-29-2014, 10:30 PM
ade
ade's Avatar
A lot. A lot lot. But not when it rubbed because gear was at campsite and had soft top on. However had five people--my daughter's family, two USAF members, a gymnast, and her skinny brother, so please don't jump to incorrect conclusions on their weight. All four of them are not particularly large. It is such an easy thing to trim to avoid the issue, I have no idea why people argue over it. Trim. Don't trim. The only thing I'm calling BS on is when people write it can't rub. Yes.It.Can.
Likewise, I call BS on anyone saying you MUST trim for 35s. Wasn't jumping to anything, was just inquiring on what made up the 1ton of extras you were carrying.
Old 10-30-2014, 02:48 AM
And I didn't write that, did I? So why are we arguing?
Since I'm on my computer now, instead of phone, here are pictures of my Jeep, including an image of my mods (in case you can't access them on whatever device you use to browse the forum under my profile) ...
Old 10-30-2014, 08:19 AM
ade
ade's Avatar
Attachment 582246
You did state in post #13 that "you do need to trim". No we are not arguing, we are documenting our own ideas and findings for others to read and hopefully find useful. I found you information on airing down interesting and plan on using the GoPro next time I'm on the trail to see how close my tires get in a similar environment.
Very nice rig sir. You certainly know how to go prepared. There is a kitchen sink somewhere in there right ??
Quick Reply: 35" Tire Question
