Airbag Light- NOT Clock Spring???
Hey everyone. I'm having a problem with my airbag light on my 08 with 86,000 miles.
The horn still works & I tried the steering wheel test, turning it to both sides while parked but the light illuminates immediately; which leads me to believe it is not the clock spring.
What else could it be?
Thanks in advance!
Thanks in advance!
Not sure how accurate that test is.. But it's an issue a lot of us (2008 owners) have dealt with. Mine messed up around 75,000 and I filed my complaint with NHTSA. My horn still works, just as yours does. Good luck with yours and hopefully yours is an easier fix , like maybe just a loose connection somewhere.
I just got my clock spring replaced. It's not a recall, but an extended warranty till 2017.
My airbag light stayed on, but the horn would work once in a blue moon.
What year is your Jeep? Did you have an extended warranty? How did you get it replaced? Did they send you a letter?
I just took it into the dealer and they told me your vin is not selected for a recall. Luckily someone told me that Chrysler extended the warranty on all 07 and 08, so went back in and told the service advisor and BINGO it was true!
I have the 07.
I have the 07.
