another tpms question
Old 11-05-2012, 03:01 PM
Angry_Fisherman's Avatar
Default another tpms question
Well, the Rubi take offs i bought didn't seem to have the TPMS sensors. But the price I paid for 5 tires with less than 100 miles and rubi rails was more than a steal. This was questionable when I bought the tires because when I asked the guy he didn't know what TPMS was... I still have my stock tires which came with my JK sport wth the TPMS sensors in them.
I've been driving for 3 days with correct tire pressure and the TPMS warning light still hasn't turned off.
1) Is there a way to take them out without removing the tire from the rim?
2) Any tips on actually making sure there is no TPMS sensors in the tires before I go to the tire shop to have them swap them from old tires to the new ones?
Old 11-05-2012, 03:13 PM
JK-Ford's Avatar
The tires have to separated from the wheels to take out the TPM devices. And the tire / wheels will have to be speerated on the new set to install the TPM modals.
I think that the TPMS valve stems are not flexible.
Old 11-05-2012, 03:20 PM
ronjenx's Avatar
By separated, do you mean taken off the wheel?
Old 11-05-2012, 03:24 PM
JK-Ford's Avatar
I gues you could remove the TPMS just by simply breaking the bead. But IDK.
Old 11-05-2012, 03:32 PM
ronjenx's Avatar
That's what I was seeing in my mind.
Old 11-05-2012, 03:49 PM
catahoula's Avatar
I took my tires I bought to a tire place. They had a hand held machine that could read the sensors without taking them off the wheel. They took out my tpms on 16's stock sport and put on 17 Rubi wheels. Have not had any problems.
Old 11-06-2012, 12:45 PM
I stopped by the Firestone tire shop on my lunch break, the guy quoted me $103 to swap them. No thanks. I could probably get it done for that price or less at the Stealership. I'll run it by an independent shop over the weekend.
Also are the sensors the same Mopar part # for both the Sport and Rubicon? I know from reading here a lot of folks have swapped them, but the guy was trying to lead in the direction that he could only do it if they are compatible....
Old 11-06-2012, 05:40 PM
Flip94ta's Avatar
The only difference in JK's is split by 2012 and older or 2013 and newer.
Old 11-06-2012, 08:00 PM
Well I have a 2011 and the tires and rims came off a 2012. I'm thinking I should be ok then. Just have to find a shop that won't charge me over a hundred bucks for a maximum of 30 min of labor
Old 11-10-2012, 10:50 AM
Zylfrax791's Avatar
I've heard the alternative the tuner crowd uses is to make a closed PVC container with the TPMS sensors inside. You pressurize it, clear the code and then no worries.
http://www.propickupmag.com/tpms-sensor-canister/
Quick Reply: another tpms question
