Beware of those felt pads for the battery posts
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Join Date
    Oct 2007
    Location
    Delray Beach, FL
    Posts
    159
    Default Beware of those felt pads for the battery posts
    Beware of those felt pads for the battery posts. I recently got a new Duralast Gold battery. They gave me felt pads with the battery, to help avoid corrosion.
    I thought I got the battery post clamps tight enough with those pads on. I had a couple of glitches riding down the highway the other day. (Radio reset, lost Sirius, lost station presets... but then got it all back few mins later.)
    I opened the hood when I got home, and sure enough, I could wiggle just slightly the positive post.... damn!
    I took those stupid pads off, cleaned and tightend the hell out of those clamps, then sprayed them with that red protectant sold at parts stores, and the problem is solved.
    My assessment of what happened is: The posts taper towards the top. The felt pads kept my clamps away from the bottom of the post. (This is the first vehicle I've owned with a spring steel clamp, instead of the older lead style clamp.) This 'clamp lift' kept me from getting a tight grip on the post.
    So, I don't know if others have had a similar experience. Or, perhaps I'll save someone the bother I had with it. Thinking back on it now, I don't know why I even tried those felt pads... I have never had a corrosion problem that wasn't solved by a simple cleaning, and the red anti-corrosion spray.
    So, Lift your Jeep if you like, but DONT LIFT YOUR BATTERY CABLE CLAMPS!
  2. #2
    JK Jedi Master Mark Doiron's Avatar
    Join Date
    Mar 2007
    Location
    Midwest City, OK
    Posts
    13,629
    Spray the battery posts with a quick squirt of WD-40 when you change your oil. And don't mess with any of that other nonsense.
  3. #3
    JK Super Freak Lorrel's Avatar
    Join Date
    Apr 2007
    Location
    Lancaster Pa
    Posts
    1,692
    I;ve had those felt pads on my 94XJ. Put them on about 2 weeks after I got it back in 94. In 98 when the battery went, I got an Optima and a new set of felt pads. In 05 when I put a new Optima in again the felt pads, they're still on that battery. Had no problems ever with lugs loosening up.
    Bought the Jk for the wife in Oct 06. One of the first things I did was install the felt pads. They're still on, and again no porblems with the lugs comming loose.
    Don't know if the pads really do anything but i have no corrosion around the terminals. Of course I clean the engine bay every time I wash the vehicles.
    "And with one Voice, the People may express the grateful feelings of their hearts, and consecrate themselves to the service of their Divine Benefactor, to afford His blessing on the Governments of these States respectively, and prosper the public council of the whole with that Wisdom and Fortitude which may render them fit Instruments, under the Providence of Almighty God, to secure for these United States, the greatest of all human blessings, Independence and Peace."
    www.pafoa.org
  4. #4
    Join Date
    Aug 2007
    Location
    Hammond Louisiana
    Posts
    15,666
    I have pads on the Duralast Gold aswell, no probs here.
  5. #5
    JK Freak derff96963's Avatar
    Join Date
    Jan 2007
    Location
    Mt Pleasant, PA
    Posts
    499
    I used to work at a National Auto parts Chain and have changed probably over a hundred batteries. Never had a problem with the felt pads being on there. However I do not like that red anti-corrosion spray you are talking about. I will not use that and will immediately clean it off if someone would put it on.
    2007 JK X Unlimited, Red, Hardtop, Auto
    1982 CJ-7 (My beater for the hard stuff...)
    http://www.northridge4x4.com/
  6. #6
    JK Enthusiast hiddenprey's Avatar
    Join Date
    Jul 2008
    Location
    Morinville, Alberta, Canada
    Posts
    395
    Default Felt Pads
    That must be something you guys use down there, i have never seen them up here in Canada. I work with many diffrent types of batteries for my job and never used Felt pads,
    we also use "NO OX" it is a die-electric grease, alittle messy but works the best
    Tony
    "X" unlimited detonator Yellow
    i live. i ride. i am......Canadian!
  7. #7
    JK Junkie robin's Avatar
    Join Date
    May 2007
    Location
    slp. Mexico
    Posts
    3,932
    thanks for the warning
  8. #8
    JK Enthusiast jeff@zina.com's Avatar
    Join Date
    May 2007
    Location
    Naples, FL
    Posts
    290
    My battery on my '07 died and was replaced under warranty, they added the felt pads at that time and haven't had any troubles. I'm in SW Florida, battery killer zone. I haven't had batteries last long enough to get seriously corroded terminals. I also hit them with WD40 when servicing under the hood.
    Jeff
  9. #9
    JK Jedi RevyJKU08's Avatar
    Join Date
    Oct 2007
    Location
    BC
    Posts
    4,730
    No felt pads for me. I usually add Vasoline over the clamps and battery posts....seems to help with corrosion.
  10. #10
    Join Date
    May 2007
    Location
    slp. Mexico
    Posts
    3,932
    Quote Originally Posted by TripleJeep_99 View Post
    what is vasoline?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
