Death Wobble??
Death Wobble??
Just wondering how many JKs have had death wobble after the owner tried to fix it without ever experiencing it? Also do you think you might have caused it?
Thanks y'all!! What size is your lifts? I am putting on the TeraFlex 2.5" coil lift this weekend and am a little nervous!
Also I am wondering if anyone caused it by doing preventive measures like the grade 8 bolt kit or something else? Thanks!!
I would bet that death wobble is more correlated to wheel offset than lift. Think about it, if you push the wheels and tires out more, you're increasing the track width beyond what Chrysler deigned the front-end to handle. It's already ridiculously wide on a solid axle, so increasing the width just increases trouble. It's what makes me nervous about new wheels and tires, or adding spacers to my stock wheels.
I have a 3" lift and 35's with good back spacing (tires poke out of the stock fenders by about 2") and everything was great until I smashed my steering stabilizer on some ruts. The stock stabilizer is pretty pathetic, I'm waiting for my superlift stabilizer that relocates up higher. I wonder how many death wobbles are caused by worn out/damaged steering stabilizers.
(Note: Getting improved steering stabilizer has seemed to help reduce it a lot!)
I had a 4" procomp lift put on mine about a year and a half ago. I got DW about 4 months in. Since then I have gone through 3 steering stabilizers (stabilizers aren't the problem by the way, they are only support for the suspension), added adjustable lower control arms, had some other welding and fab work done, track bar relocate and new dropped pitman arm. All this was done because the castor was off the problem is the usually is the castor is moved from center causing the death wobble. Once all this was done I thought I had it fixed because no problems for the last 7-8 months. I'm bringing it back in on Monday because the DW has resurfaced for a fourth time as of this morning(great timing for this thread by the way). I am going to go to 3" coils and hopefully this solves my problem as everyone who I know who has 3" or less has not had any problems (wish my girl agreed with that). Does anybody think this will help or should I just start over with a whole new kit wallet is getting thin
I would suggest paying the money and going with a full short arm or long arm kit, don't skimp with a coil and shock only lift like I started with trying to save $, you will most likely end up spending the big dollars. I could've had a full long arm kit with how much time and money I've now vested.
I have also heard good things about the 2.5" budget boost..good thing about this lift is you don't change the geometry too much and your chances of DW are much less likely.
J-Just
E-empty
E-every
P-pocket
J-Just
E-empty
E-every
P-pocket
