Field mouse was in my engine
#22
Same problem here. No real damage so far. Just a chewed up owners manual and a nice cozy nest in the glove box. Never did find the little bugger. I guess it's kind of inevitable since I live on 12 wooded acres and leave the top and doors off all summer. (btw, it's always parked on gravel, so I'd have to say that solution is debunked). I will definitely try the dryer sheets tho
#23
Yes. I own a business and we park our trucks on a gravel lot. We have a lot of mice problems. They get in the trucks and my camper that I have parked there. I haven't found anything that works. I bought some of the packets that put out a scent that supposedly deter mice. It did not work at all. Traps are your friend.
#24
I have ordered some small plastic containers and some magnets. I think I'll drill some holes in them, put mothballs inside and stick them on the underside of the hood and see how that works. I'll try the bar of soap in the glove box trick too.
#25
I haven't had any mice problems (knock on wood) but I did have a squirrel build a nest in my engine bay. I have my suspicions that dryer sheets would just likely provide him some more material to build his nest with and give him a fresh smelling pillow/blanket. Any suggestions for squirrels?
#27
#29
slightly bigger than a mouse
ran into a guy while up in the mountains near Animas Forks that had a marmot in his engine bay. Used a hiking pole to try and help him scare it out of the compartment. the thing ended up taking chunks out of the hiking stick with its teeth. Finally we got it to run out the bottom and scamper away. The guy said a marmot had stranded his friend before by chewing a fuel line in half.
#30
I would have started up the engine. Killed a cat that way, cat never went there again. But that was when the fan was attached to the engine and when the fan grabbed the leg or tail it was all over
