Freedom Tops
Freedom Tops
Has anyone experienced their freedom tops taking in water with heavy rains while its parked? If so what did you do to correct it? Mine just started doing this and its getting aggravating, getting in and having water pour down from the top right onto legs and/or shoulders.
Thanks
Thanks for the guide, I'll go through it hopefully this weekend. Although I really didn't see the areas of concern in the guide. I'll check areas to see if they are the culprit. My tops are actually getting water inside them and then leaking out of the line up post area and the rear screw hold down area.
It is a 13 model but warranty is long gone.
Before doing anything else take your top off and clean the seal both around the jeep and the tops. Put back on and test (with hose) then go to more extreme measures
Water IN the panels? As in, if you were to take them off, you might hear or feel water sloshing around in there?
That's not good. There's a hole or crack somewhere that needs to be addressed. You'll need to do some advanced troubleshooting, i.e. maybe filling up a kiddie pool and submerging the top panel and watching where air is escaping. Then drain the water, repair the hole, and refit the panel.
If there's not water inside the panels, then it's a seal-related issue. Usually always is. They're extremely finicky and if the seal has been damaged in any way, leaking is inevitable until it's repaired. Water might not be coming from the exact location of the leak, so it makes it hard to troubleshoot.
My hardtop leaks during the rain. I replaced the b pillar muckets. I have given up trying to fix the problem. Easier to clean up the water, dry the seat belt, etc. Carpet has been removed from the back seat for years.
I may have misunderstood your problem - are you saying that you open the door when it is raining and water runs down onto the carpet towards the front of the door, getting you wet while getting in or out? If that is the case different answer, that is a design issue - no rain gutters and it will happen all the time.
