Front End Removeable Winch mounts?
So I purchased a winch and now I'm starting to plan out how I'm going to mount this thing on my JK.
I really want to go with some kind of quick disconnect removable option for 2 reasons.
1. I'ld like to be able to move the winch from the front and put it on the rear if needed.
2. Would be nice to store the winch in the garage when I'm not using it, to protect it from the elements.
I know for reason 1, there are winching techniques to keep the winch on the front and be able to pull your Jeep backwards. However, when I look at those, they seem to rely upon having 3 different trees/anchor points in the correct positions and when you get stuck, who knows if that is going to be a feasible option? Chances are I'ld be wheeling by myself with friends and family onboard, without another vehicle around to help. So, if I get stuck going forward into a mud hole, I would like to have a more reliable option of pulling the winch off the front and putting it on the back and pulling myself backwards from which I came.
So, I'm thinking right now that a hitch mount would work best for me. (Yes, I've already read how that isn't the safest or most secure mount, although would like to hear ways to make it more secure and safe). However, when I look at the front of my JK, I'm not sure of the best place to install a hitch mount on the front. Not sure if I need a new bumper. Not sure if there is a removable winch mounting option without needing to use a hitch mount that will work on the front and rear.
I'm really looking for some ideas, some of you might have already done when installing a front end mounted winch that can be easily removed.
Olympic 4x4 Products 533-171 - Olympic 4x4 Products Front Rock Bumper with Hitch for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
The only thing I've found so far is a bumper replacement made by Olympic. That might do the trick, but just not sure of how secure/strong that hitch receiver is welded on that bumper.
Been thinking about buying a welder though, taking off the front bumper and trying to figure out the best way to weld some kind of mount to the frame.
Ok, here's my current solution idea for the removable front mount.
Get this front end hitch by Hidden Hitch. It says in the product details, it can handle up to a 9000lb winch.
Then, I'll probably go with the Warn removable hitch mount or something similar.
I've considered going a similar route, but the biggest issue I see is that a front receiver will hang to low and cause the winch to be too low and too far out front. I've gone down some extremely steep things in Moab, and I can see a winch out front like that would be a problem. I think up on top of the bumper area and closer to the grill would be better if something could be fabbed.
It sounds like I definitely need to pull off my front bumper and see what kind of options I have to work with so that receiver is up higher.
I have some great ideas to put a mount up on top for you but I dont want to have to pull my bumper off to draw it up, my idea also adresses the side to side, and twisting strength that warns mount lacks. warns mount is decent but it has to try and fit every application
So you have the ability to cut steal and weld it to actually fab something yourself?
