Fuel efficieny hints: tricks to getting good gas mileage and saving money
#51
So what your saying is that I think its a radical idea not to mod a Jeep? Well since mine completely stock........ I must be radical. Mod or don't mod, neither is radical.
#52
Is this really still a topic? Drive a reasonable 55-60mph on the highway and enjoy the mileage. I elect not to do 60 and thus I elect to get 17mpg. Easing to 60 would but me at 21ish, based on multiple runs.
#54
I don't have the formula in front of me but I am pretty sure you do multiply by the Cd.
Good point. And you won't save any fuel. In fact you should just decelerate in gear and don't put in the clutch because there's a fuel cutoff during deceleration in gear but if you idle you will burn more fuel during deceleration.
To anyone thinking of shutting your engine off downhill on the road - please don't.
#55
It appears people can't help themselves but to provide nonproductive comments on threads in which a person new to the wrangler world, me, would like a bit of advise.
13 mpg for driving like a grandma is poor performance, even for an unmodified JKU. As it goes, carbon build up and poorly performing injectors were the culprits, no thanks to a handful of comments. For the positive suggestions, thank you. A motor is a motor is a motor. I'm currently unfamiliar of this particular one, but I am learning there are a lot of jackasses trolling these forums.
#57
Those are just ordinary Jeep owners, or so I have found. Not necessarily unique to this particular forum, but it seems to be somewhat par for the course on Jeep forums.
This is probably the thing I hate the most about owning a Jeep. I had much higher hopes after nearly two decades on the Miata forum. I just guess there's something about Wranglers that attracts large numbers of a certain type of buyer.
#58
#59
Former Vendor
Here's a list of CdA values for many motorcycles (in m^2): Motorcycle CdA Values
And this page has Cd, frontal area, and CdA values for many cars (in ft^2): Vehicle Coefficient of Drag List - EcoModder
There's a soft top TJ Wrangler listed there with a CdA of 16.45 ft^2, which comes out to about 1.53 m^2. COmpare that to the CdA of the motorcycles.
Also, the power of aerodynamic drag is proportional to the CUBE of the speed; not the square. It's the force of aerodynamic drag that is proportional to the square of the speed. Revisiting your example of 75 mph vs 55 mph, it takes about 86% more force and 154% more power to maintain 75 mph vs 55 mph.
https://en.wikipedia.org/wiki/Drag_(physics)#Power
~Jeff
#60
~Jeff
~Jeff
Lower highway speeds are an important key to good highway MPG in most cars, and particularly the Wrangler. There are rare exceptions such as if the lower speed requires a downshift and the lower gear puts the throttle position and rpm in a range where the engine's computer runs more enrichment or runs in open loop. I doubt this is the case for a JK especially with the Pentastar since it has abundant [enough] torque at very low rpms to sustain even pretty low speeds like 40mph in 6th gear (manual).
Back when we had a Honda Element, it would get nearly 30mpg on the highway if you kept under 60mph but barely above 20mpg at avg. 65mph. It can really make a huge difference.
