Rubicon and lift.
Old 05-07-2010, 08:29 AM
JKChandler's Avatar
Default Rubicon and lift.
Sorry if this was posted elsewhere but couldnt find anything on a search.
Anyhow, getting ready to get myself in to a Rubicon but was curious about aftermarket mods.
If I went with a lift to get 35's on it, will I lose the front sway bar disco's or lockers? I keep seeing varying detail on this.
Any insight will be much appreciated.
Thanks,
Old 05-07-2010, 09:08 AM
john smack's Avatar
I have a lifted Rubi and the lockers and swaybar works fine
Old 05-07-2010, 09:29 AM
Dex1's Avatar
Nope, won't lose a thing!!!!
Old 05-07-2010, 01:45 PM
JKNIGHT's Avatar
you will be alright..
Old 05-08-2010, 03:08 PM
Simply Jeep's Avatar
With a lift, you will need longer front sway bar links. The stock front sway bar links are 5.5". For example: With a 3" lift, you will need front links of about 9"
Old 05-08-2010, 07:35 PM
CreepJeep's Avatar
I lifted mine 2" with a BB.
everything works great just like it did before the lift.
I didn't add anything but new shocks and the spacer pucks.
Old 05-08-2010, 08:14 PM
You links could flip over at full flex (disconnected). Trust me, you need longer front links. There are many threads about this.
Old 05-09-2010, 06:52 AM
RevyJKU08's Avatar
I went longer links with a 2" BB because of the chances of the swaybar flipping. I added adj front swaybar links to run the swaybar at slightly up from neutral.
Old 05-09-2010, 08:58 AM
Sponsoring Vendor
Off Road Evolution Rep
serveapurpose's Avatar
Welcome you will not loose the use of your electric sway bar nor your lockers. Most kits come with new swaybar end links that are the correct length for the kit or will have you swap your current front links to the rear and included links to the front, like Simply Jeep stated.
Quick Reply: Rubicon and lift.
