Jeep won't move in gear
Had a new clutch put in a few months ago and have had absolutely no problems with it but today it just does not want to move. I can shift into gear, 1st, reverse goes into gear as smooth as always but it will not move an inch. Any advice on what this could be would be greatly appreciated, thanks!
07 Unlimited Sahara
07 Unlimited Sahara
No, I cannot push the Jeep if it's in gear it will not move. I can put it into gear without the clutch but it grinds a little in first gear, it seemed to slip into second with no effort without the clutch.
Either the hydraulic piston is holding the clutch disengaged or the clutch is toast. Have not removed the slave cylinder from a jk so don't know but if like ford you can twist it counter clockwise to remove it and that will rule it out if you then can't put it in gear. Should not even come close to being able to put in gear without clutch disengaged.
When you had the clutch replaced do you know what all parts were replaced?
