JK Gremlins and Mystery Noises
Thought it might be interesting for people to post up solved and unsolved mystery noises from their JKs. The smaller and more irritating the better: the kind of problem you dread having to explain to a service advisor. Mine involved an annoying rattle at highway speed. Turns out a fender clip (probably loose from the factory) had come off inside the driver's rear fender well and was ratting around. I finally found it stuck between the rock rail and the fender.
Originally Posted by JKJA10
If there is one thing I can not stand, that is a rattle. That is the most annoying thing be glad you found it.
I had a neighbor stop me when I was going down the street to tell me my rear end was making a grinding sound. I was a bit panicked because he's a pretty good car guy. I had my wife drive it and heard the noise but it was more of a rattle. After climbing under I found some debris stuck between the muffler heat shield and the body that was rubbing on the heat shield & making the noise.
Tailgate rattle is pretty annoying.... basically the only thing I have found to work (after several trips to the dealer) is to grease the latch really well.... get a tube of grease and a brush and re-grease it every 2/3 months and you are golden.
