Legal front bumper in Canada - Help Please
#21
49(2) No manufacturer of motor vehicles of the passenger car type, and no distributor or dealer of motor vehicles of the passenger car type, shall sell, offer for sale, or have in his possession for sale, a motor vehicle of the passenger car type of the model or make of the year 1973, or of any subsequent year, unless the motor vehicle is equipped with an appropriate energy absorption system which complies with the standards prescribed therefor under the regulations.
So, can I mod my Jeep with a new steel bumper or not...
If so... which one is legal?
Please help me.
*Yes, I live and registered in Manitoba.
#22
BUMPERS
16.1 Every special motor vehicle of the passenger type shall be equipped with a bumper both on the front and rear of the vehicle.
16.2 The bumper width must cover the full track width of the vehicle.
16.3 The horizontal bumper of customized bumper or grill bar structure shall be at least 76mm.(3in.) in vertical height and centered on the vehicles center line and securely fixed to the vehicle and designed to minimize damage.
16.4 The bumper shall have no sharp ends and the ends shall angle towards the body.
16.5 The bumper shall be constructed of non-splintering material.
16.6 Original Car Manufacturers designs are acceptable.
16.7 Bumper Height Measurement Procedure - measure on a level surface the height of both front and rear bumpers to both the top and bottom of the horizontal bumper bars.
16.8 Bumper Height Requirement some part of the horizontal bumper must fall within 350mm.(13.7in.) and 560mm.(22in.) above the ground level surface. (See also red text below for trucks &c)
16.9 Every modified vehicle that is a truck or multi-purpose passenger vehicle having a gross vehicle weight rating of 4500kg or less, the following shall apply:
a) There shall be a front bumper of at least 100mm.(4 in.) in vertical height and extending to the width of the vehicle manufacturer's track width.
b) The bumper shall be of non-splintering material with no sharp ends.
c) Bumpers shall be of sufficient strength and so attached to the vehicle frame so as to effectively transfer impact loads to the frame.
d) Dropped bumpers shall be horizontal, at least 100 mm. (4 in.) in vertical height and continuous across its normal width or shall consists of separated sections. Separated sections shall not be less than 100 mm (4 in.) high and 100 mm (4 in.) wide and shall not be more than 300 mm. (12 in.) apart.
e) All bumpers shall have a foremost contact point at the bottom of the bumper not to exceed a maximum height of 740 mm. (29 in.) above a flat surface upon which the vehicle stands at curb weight, unless originally equipped.
So it's now not just for commercial vehicles?
#23
Sec 16 of the CHTA is for Commercial Vehicles....
Sec 16 of the Manitoba Highway Traffic Act IS applicable.
A modded Jeep is considered a Type 1 Special Vehicle.
TO CLARIFY!
It appears that FULL WIDTH STEEL BUMPERS MOUNTED ON A FRAME WITH DESIGNATED CRUMPLE ZONES (Jeeps Are) AND MOUNTED WITHIN THE PRESCRIBED HEIGHTS WILL BE LEGAL IN MANITOBA.
TO CLARIFY!
#24
TO CLARIFY!
TO CLARIFY!
So...
In your opinion, the "LoD Full Width Bumper" will be legal in Manitoba?
*Thank you for your time.
LOD Full Width Bumper:
#27
Thank you!
I am stock, for now.
Planing to have the "1.5 Teraflex performance leveling kit" and maybe, just maybe 33"...
Some day in the very (VERY) far future, 35" with 3" lift (final goal)
I don't want to buy front steel bumper twice... so I'm asking all the question.
#28
BUMPERS
*snip*
*snip*
#29
Click Here
This is not an official Gov MB web page but it does contain the information your local inspection shop uses.
