Lift?
Old 04-23-2016, 02:07 PM
TheDirtman's Avatar
Actually in mud you want a big wide tire(large contact patch) for floatation, same with snow. ice would be the only place a small heavy contact patch would be of an advantage. Just because you don't understand the advantages of a flatter rolling arc does not mean I am not correct. Weight of the tire is really is not relevant.
Old 04-23-2016, 02:10 PM
NCRUBI2012's Avatar
Possible idea
2.5 lift with 35"
Old 04-23-2016, 02:55 PM
Panthro1810's Avatar
It's going to be for back and forth to work beach and trails no rock climbing. Do you have pics of the 35 with no lift?
Old 04-23-2016, 03:20 PM
Mark Doiron's Avatar
When I see these discussions I think of the king of wheeled (not treaded) vehicles for work in mud and the tires it has: A tractor. The Brits are really into tall, skinny tires for that flatter rolling arc, and consider our infatuation with fat tires a bit limiting for off-road performance.
Old 04-23-2016, 03:52 PM
karls10jk's Avatar
This is 35's with no lift on stock wheels and simple wheel spacers.
Old 04-23-2016, 06:07 PM
35x12.5?
Old 04-23-2016, 06:16 PM
karls10jk's Avatar
Yes, 35*12.5-17 km2's on stock wheels. It can be done but in that style, it's not going to play off-road. More bumpstop and less flare- you could play. I run 33's since I'm realistic about my "wheeling" and actual jeep use. I do many highway miles so the 33 is a practical choice. I chose trails to where I don't need the extra ground clearance.
Old 04-23-2016, 06:35 PM
Yes I'll be doing mostly highway miles as well and beach occasionally in the summer. So I see you say go with 33X12.5 with no lift.
Old 04-23-2016, 07:20 PM
What I have in mind
ID:	644822   Click image for larger version
ID:	644823   Click image for larger version
Old 04-23-2016, 07:34 PM
karls10jk's Avatar
I'm all highway (130k+ miles now) with frequent trips to the beach. My rationale behind a lift was to increase my uptravel so I'm not bottoming out on the bumpstops running down the beach. The 33 will leave you plenty of power on the road and beach.
Your tire choice is one I ultimately decided against due to a lack of siping. Siping really only comes into play in wet and icy conditions. Of your two lift choices- I personally prefer the ride of a full coil lift. In the x amount of inches of space in the coil bucket, a full coil lift will allow you to utilize all of that space. The spacers only allow the stock coil length to work and the top 2" are static. I had a coil spacer kit and quickly ditched it.
Standard disclaimer- your mileage may vary and opinions are like.....well I think you know how that one goes.
Quick Reply: Lift?
