Looking for some help?
So a couple weeks ago, I took my Jk through the local mud bog, and had to replace my radiator fan assembly, due to mud build up. The problem I am having now, is my jeep is running hot. I cleaned out the fins on the radiator, new fan & blade and new thermostat, also did a complete coolant change. I don't have any leaks,that I can see, the water pump s working fine. No noise from pump either. Oh, it heats up quicker than normal. Has anyone encountered this? Looking for some advice?
Please help?
Please help?
I would have to go outside to look under the hood. Cant remember if there's a oil and trans cooler under there. But it may sound like a stupid question but is the polarity correct on the new fan.
JK Forum Regional Rep
Most likely the radiator is still blocked.Had the same problem,took awhile to get all the mud out.Make sure the fan is coming on,check the temp sensor in front of the radiator
Do you mean heats up quicker from cold to 180? Or overheats quicker? If its cold to warmed up real fast it might be an engine or oil problem. If it overheats fast, does you fan turn on? Fuse blown? Is it blowing correct direction?
Thats a good point. Also when you put the new fluid in the radiator did you let the engine idle long enough to allow the thermostat to open or did you just fill it and put the cap on.
I did just about everything you all have mentioned, except "burp" the radiator, or take the radiator completely (its a pain in the A**). but it looks like i should do another oil change, and try pulling the radiator. As far as the fan, I thought about that too, i don't believe its running backwards, have too look again.
thanks everyone for the advice. I will post what I found out.
thanks
thanks
Status update
So I spent another 2+ hours cleaning my engine compartment/radiator. Still running really hot. When I say really hot I mean above 210 degrees the temp gauge reads at the 3/4 mark to the hot(if that makes sense). Fan works fine/ blowing the right direction. Haven't pulled the radiator out completely yet. Just haven't had the time. I did "burp" the radiator though. Nothing change. Should I just buy a new radiator and say the hell with it and clean it when I have time, to use as a back-up.
Check the thermostat to make sure it's opening fully. I've bought many bad ones over the years.
As for the radiator, try taking a flashlight and put it on the back side. Look from the front. If light passes though, you should have most of the mud out.
