My spacers bolts and nut is rusting
Galvanic corrosion - dissimilar metals in contact in the presence of moisture. One metal becomes an anode and the other is the cathode. Basically it is the same reaction as a battery, and ions are being conducted from one surface to the other. A good cleaning and a light coat of anti-seize to keep moisture out should do the trick.
I've never seen aluminum lug nuts, only steel. When a lug stud has a lug nut screwed onto it, any corrosion coating or protection is scuffed off the threads. A light rust sometimes will form. No big deal as far as function goes. I would be extremely careful using anti-seize compound on any lug nut/ stud assembly, especially a double set such as wheel spacers. The lug nuts remain tight by the torque applied actually ''seizing'' the thread surfaces of the lug nut and stud and the face of the lug nut upon the wheel. All shop manuals recommend dry lug nuts and studs.
