Rear window removal
Old 04-24-2014, 05:44 AM
jellis07109's Avatar
Default Rear window removal
Im planning on removing my hardtop. But in order to do that. I have to go up a flight of stares and thru a semi narrow passage to store in garage (my driveway is separate from my garage). Anyway i dont want to pick it up and go up the stairs with the rear window hanging down. Is there a way, an easy way, to remove the rear window from the hardtop?
Old 04-25-2014, 10:59 AM
Maxamoose's Avatar
Another person here wondering same thing. everything appears straight forward except the window defroster wires. Any thoughts
Old 04-25-2014, 11:15 AM
roscoj's Avatar
I remove my window all the time.
Undo plug
Undo washer tube
Pop off defrost wires
Undo struts
Undo bolts
Takes less than 5 minutes
Old 04-25-2014, 11:21 AM
Rbzak's Avatar
R the nuts on the hard top itself metal inserts?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-26-2014, 12:21 PM
Maxamoose's Avatar
How does one "pop off" defroster wires.
Old 04-26-2014, 07:40 PM
roscoj's Avatar
The wires pop off the glass like a snap you would find on clothing. Atleast that's how it worked on my 09. I have a 14 now and haven't tried it yet. I use a flat head screw driver to seperate the two halves.
Most of the time I just leave these disconnected for summer since there's no need to use the defrost.
Quick Reply: Rear window removal
