Torn between a 265 tire and a 285 tire.
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    JK Junkie Suffolk JK's Avatar
    Join Date
    Jan 2008
    Location
    Long Island, NY
    Posts
    2,319
    Default Torn between a 265 tire and a 285 tire.
    This is mainly a daily driver vehicle that sees occasional offroading from time to time but will see a lot more in the VERY near future due to a local offroading association that I just joined.
    I'm torn in between a 265 tire and a 285 tire. This is on a stock X with 3.21 gearing and the 6-speed tranny. I've heard, read, and found that the biggest you should go on 3.21 is 265. But, on other threads, I've seen people run the 285 and had no complaints.
    Both tires are the SAME PRICE.
    I really need to have my 6th gear on the highway, above 65mph. I can't lose that gear, just for a tire.
    I'm not planning on regearing anytime soon, so, this tire will possibly be on for a good 6 months to a year, AT LEAST.
    What do you guys recommend?
    2008 Jeep Wrangler X 2DR dubbed RED WONDER WAGON by Evan
    Lots of mods.
    Long Island Off Road Club
    liorclub.org/Members/dimi
    NOVA4x4
  2. #2
    JK Junkie wayland1985's Avatar
    Join Date
    Jul 2007
    Location
    Boston, MA
    Posts
    3,190
    the 265 and 285 are widths. How big of a tire did you want to run??? We need the aspect ratio and rim size to know what you're looking at!
    2007 Wrangler X 2Dr
    Sunrider Soft Top
    3.21
    255-75R17 Goodyear Wranglers on Moabs
    Jeep Rubber Floor Kit
    Mastercraft Grab Handles
    OME 2" lift (standard springs and shocks)
    Teraflex bumpstop extensions, brake line extensions, rear swaybar links
    JKS front and rear trackbars
    Currie Lower front control arms
    Teraflex 2.5BB (w/ Shock extensions)
    Spidertrax spacers
    Kicker/Mopar Speakers
    Iggee Seat Covers
    Bestop Trail Cover
    Clover patch Window Roll
    www.cop4x4.com
  3. #3
    Join Date
    Jan 2008
    Location
    Long Island, NY
    Posts
    2,319
    Sorry, 75 R16, on both.
    Lots of mods.
    NOVA4x4
  4. #4
    Join Date
    Jul 2007
    Location
    Boston, MA
    Posts
    3,190
    Honestly, there's only about an inch of difference in height. I don't think the difference in performance loss is something you'd notice, unless you were Mario Andretti.
    I'd go with the larger. The real question is, if you're using stock wheels, if you'll have any rubbing issues without spacers.
    If I remember correctly, the 3 or 4 people running the 285's on the stock 16's had no rubbing issues. But I may be wrong.
    2007 Wrangler X 2Dr
    Sunrider Soft Top
    3.21
    Spidertrax spacers
    Iggee Seat Covers
    Bestop Trail Cover
    www.cop4x4.com
  5. #5
    Join Date
    Nov 2006
    Location
    Posts
    15,177
    265 75/16 is about 31" tall. The 285 75/16 is about 33" tall. If you are planning on doing more wheeling I would suggest the 285 75/16. I made the mistake of getting tires that were not large enough for what I needed at first. Personally I would suffer with the power loss, until regearing is possible, and get the bigger tire. Just my opinion.
  6. #6
    JK Super Freak LidLess07X's Avatar
    Join Date
    Dec 2006
    Location
    Pasadena Maryland
    Posts
    1,537
    size matters and bigger is always better
    My Jeep history;
    2007 JK 2 door 0n 37's
    2010 JKU on 35's
    2015 JK 2 door on 33's
    They're getting smaller and smaller. Next one will be a PowerWheels
  7. #7
    JK Super Freak Lorrel's Avatar
    Join Date
    Apr 2007
    Location
    Lancaster Pa
    Posts
    1,692
    A 265/75/16 is about 32.8 X 10.4, whereas a 285/75/16 is about 32 X 11.2.
    That doesn't seem like a big diference, however with 3.21 gears, it could mean alot.
    The wifes JK 4dr. is running stock 245/75/16, (30.5 X 9.6), with 4.10 gears. now this is an auto, and although I feel it's a good combination, I also feel it would be better with 4.56 gears, just to give a bit more low end power.
    I have a 94XJ 5speed that I've lifted and ran 31 X 10.50 for a bit with the stock gearing of 3.07. This was almost unbearable, and I all but lost my 5th gear. When I installed 4.10 gears it was much better. After I went to 33 X 10.50's I then wished I had geared to at least 4.56 if not 4.88. Don't get me wrong the 33's with 4.10's are okay, but.....
    With that in mind, I don't see how you are doing a 31.6" X 10.4" with 3.21's let alone a 32.8" X 11.2".
    Granted the XJ is an I-6 which has a bit less HP and torque, however not that much less, and I'm sure the JK weighs a bit less especially if it's a 2dr, however that still is some rolling resistance, and even more so with the 285's.
    I would not be happy. I would have to gear to at least 4.10's with a 285.
  8. #8
    - JK-KJ's Avatar
    Join Date
    Sep 2007
    Location
    Odenville, AL
    Posts
    1,884
    I recently had this same dilemma...I went back with the same 265/75R16 size that I had before and I'm glad I did. It all depends on the backspacing, mine is 4" which makes the tire/wheel stick out a little further which then creates the problem of rubbing on the rear fender when fully flexed. 265's are the largest that I can go on my rims, but if you have stock wheels or more backspacing the 285's should be fine. As for the power loss, I doubt it would be that noticeable....265/75R16 is about 31.5"-32" tall depending on the tire, 285 is 33" tall....so it's not a huge increase.
    If you can fit the 285's without rubbing, do it. That's my opinion.
    BTW, mine is the same 3.21/ 6-speed like yours....I can still use 6th gear at or above about 50mph with no issues, that's with a 32" tire
    '08 2-Door X 6-speed
    JEEP GREEN
    -1.75" Coil Spacers/RC 2.2 Shocks
    -Warrior RockCrawler Front Bumper
    -16x8 Cragar Soft 8's
    -285/75R16 Hankook Dynapro MT's
    -Teraflex Quick Disconnects
    -Flowmaster 40 Series
    ROLL TIDE!!
    http://www.northridge4x4.com
  9. #9
    Join Date
    Apr 2007
    Location
    Lancaster Pa
    Posts
    1,692
    Quote Originally Posted by JK-KJ View Post
    There was alot more weight to my 33 X 10.50 then there was on my 31 X10.50, and even more so when you X4 plus the weight of the spare. Each lb more means more resistance when getting started, and it puts you way down on the proper power curve.
  10. #10
    JK Freak yellowjeeper85's Avatar
    Join Date
    Dec 2006
    Location
    Cleveland, Ohio
    Posts
    947
    285... if you get the 265 you'll wish you had got the 285 shortly after.... i got the 35s and now wich i had gone 37s...
    just my two cents
    07, black, dual tops, Unlimited Rubicon
    6-spd, Back-up cam, Homebrew CAI with a K&N, 2" Throttle body Spacer, Jet Chip Stage II
    Curt tow hitch, Borla relocated muffler,
    Rough Country 4" lift with Rusty's front lower control arms, 35x12.50x17 Dick Cepek Mud Countrys, eagle alloy style 186 rims, third Row of seats, 1000 watt inverter, ProComp non-CV front driveshaft, Rough Country Dual Steering Stabilizer setup
    www.Northridge4x4.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
