Venting
Venting
Why do things always break on the weekends?
2014 jk .... Turn signal won't stop blinking & dash is complaining of low air when I know they're properly inflated.
Just wanted to vent.
Anyone know of a way to disable the turn signal until Monday?
I guess you could just unplug it? I don't know. Ha is it the actual turn signal that won't stop blinking or the arrow on the dash?
And your TPMS sensor could've gone bad, I knocked my valve stem off a while ago and didn't replace with a stock TPMS sensor and just went with a regular old rubber stem and I get a low pressure light on my dash now.
I tried finding the blinker relay to unplug but I suspect it's built into the computer.
I tried pulling fuses but that isn't working either.
The right turn signal is actually on and everyone thinks I'm turning right. I tried activating my flashers and driving like that but it flips out after about 5 min of driving. It says "turn signal on" and sounds that annoying ding like when you leave your keys in the ignition. There are so many alarms going in that I feel like it's an abandon ship alarm due to self destruction being activated. Once it does that it won't stop dinging until you literally disconnect the battery.
It would be hilarious if I had something else to drive but the wife went away for the weekend and I'm trapped at home.
Edit: I see (after reading) you have more than this. Sounds like maybe a CAN controller or control module issue, doesn't help when you have to take time off work to take care of it tomorrow.
If your going to the dealership the don't do this because if it's not happening in the repair shop they won't do anything but this may fix it try to unplug the battery for a few minutes see if the module will reset.
I know how you feel I have had 2 cjs and the one jk and have had nothing but problems out of the jk this will be the last Chrysler product I buy luckily I have the lifetime warranty but usually I end up having to fix it myself because the dealer can't
