wish I didnt lift my jk
Old 03-28-2011, 04:28 PM
nthinuf's Avatar
Sounds like there is a whole lot of "someone didn't bother to do any research" going on. Post up some specifics and we'll get it all sorted out for you.
Old 03-28-2011, 04:30 PM
Mariner's Avatar
I just put a teraflex 2,5 coil kit on mine, never realigned it and it drives no different from stock, I know its only 2.5 on mine but i think you must have other issues.
Old 03-28-2011, 04:31 PM
fett 4 real's Avatar
did you get an alignment? Sounds like the front end may not be setup right?
Old 03-28-2011, 04:35 PM
harraid5711's Avatar
I too just put on the spacer leveling kit, and am running 255/75-17. I did not realign.....rides better than stock now. Something else is definitely going on.
Old 03-28-2011, 04:49 PM
depending on what you do realignment maybe necessary from one jeep to another itll differ. Just because you handle fine doesnt mean your aligned to spec, you may be toed differently then him also so when going through a turn your tires bite while his roll to much its all very sketchy when swapping suspension parts.
Old 03-28-2011, 04:57 PM
blw
blw's Avatar
This has to be a joke. Nobody buys a Jeep for its handling, let alone puts on a lift and expects it to corner well. I have the Mopar 2" lift on my 2 door, and love it, by the way. Never got good gas mileage, with or without the lift.
Old 03-28-2011, 05:03 PM
Sharkey's Avatar
Originally Posted by RRCP08JK
16 MPG? Sh1t, I'd love to get that. I'm luck to pull 15.5 with my stock Rubicon.
X's 2...at least around town anyway.
Mark's Avatar
Sounds like this is your first Jeep. And it sounds like you should have bought an SUV. That or a tampon.
Old 03-28-2011, 05:05 PM
sringer's Avatar
I got 11 mpg before 35's haven't checked since. Ride is cruddy but it's a jeep
cppower's Avatar
Originally Posted by FrostByte
You also need to recalibrate your speedo after putting on bigger tires. Your actual mpg will be better than your computer is displaying if you don't. At minimum get a Procal, or go for a Superchips for additional tuning options. Mine actually handles better after the lift and other options so maybe there was something wrong with the install.
You can get the dealer to do this for you if you keep the tires at 32" or less.
Quick Reply: wish I didnt lift my jk
