Pinyon Mtn - Anza Borrego
Old 02-14-2017, 07:48 AM
cjnomo's Avatar
Default Pinyon Mtn - Anza Borrego
Has anyone measured the definitive width of "the squeeze" before? I have a 3.5" lift on a jkur with 4.5 BS and 12.5" wide MTRs. I'm wondering if I'll have trouble "squeezing" thru. Another concern is being off camber thru the squeeze. I'm concerned about the off camber issue going thru. I'm worried about casing the top of my jeep on the side of the walls as the jeep tilts going thru.
And on a side note.... has anyone ran the squeeze in reverse? I.e. Going up?
Old 02-14-2017, 02:35 PM
jchappies's Avatar
1st...the trail is a one way trail
2nd. you have the same setup as me and I fit just fine. the top part might be a little tight if you come in wrong and may scrap.
check out trailrecon on youtube he has a really good video of us going through it.
https://youtu.be/_P5R2Vohcvc
Old 02-14-2017, 03:27 PM
davescott's Avatar
I've come up Heart Attack and the Squeeze backwards. It's a real thrill. If you do it, try everything in your power to not have to back down Heart Attack
Quick Reply: Pinyon Mtn - Anza Borrego
