315/75R16 (35s) BFG KM2s on Pro Comp 7069s
Up for sale, 5 315/75R16 BFG KM2s on 16x8 Pro Comp 7069 Alloy wheels. The wheels are 4” back space, 5 on 5 bolt pattern. All have rock rash, some are better than others.
3 of the tires are completely fine with minor scrapes on the sidewalls.
1 tire has a patch in the sidewall and holds air fine. It can probably be easily vulcanized.
The last tire has a cut in the sidewall right by the wheel (see pics below) – not sure if it can be vulcanized or not.
All tires have between 13-15/32s of tread remaining which means they are probably at a little above half tread at this point. Pics below are of the 4 tires that just came off the jeep, i didn't bother measuring the one i haven't patched because i'm not sure whether anyone will want to use that tire or not.
First $800 takes the set, and I would prefer local pickup.
The wheels and tires are located in Fleetwood, PA 19522. Might be willing to drive a reasonable distance to meet someone if you’ll throw in $50 for gas.
Pics below
Wheels:
Pics below
Wheels:
$600 obo.
In case anyone is wondering, these tires come brand new with 20/32s of tread. These tires are only at about half tread and have lots of life left.
