Air Horns installed!
I didn't have a lot of time to take photos for a write-up but I did get the Kleinn 101 air horn installed just before shipping the Jeep....it is directly fed from the Dominion Off-Road OBA system (without a tank) using the Viair 400C compressor and Dominion Off-Road connector/hose rail setup. I then spliced the airhorn positive/negative cables, the factory horn positive/negative as well as the compressor cables into one power feed and works like a charm off of the factory horn circuit. When the alarm goes off it sets off the airhorns which drowns out the factory "beep beep" horn....but is required to have the factory horn "in line" to help with current draw to activate the airhorns in both the alarm configuration as well as horn configuration.
https://www.facebook.com/photo.php?v=600377563381306&l=3415558168615879415
Be sure to turn your volume up on the computer!
