Another mans shift linkage repair
I'm confused.....(which is typical for me)......
If you could use channel lock pliers to "move" the transfer case position to neutral, couldn't you move it to 2WD, and drive off into the sunset?
Great write up, by the way!!
The bushing on the transfer case end should be replaced as well. I just haven't yet because it is still holding. For the moment.
Thanks for the comment!
Yes, you are exactly right. However, I wanted to hook it up behind my motorhome and tow it for a few hundred miles. Getting it into neutral was what I was trying to do. I did put it back into 2 WD once I got where I was going. Then I moved it to where I could work on it and completed the fix.
Mine broke yesterday at the beach, drove it home about 60 miles in 4high. Got it into 2H this morn by holding it on and shifting the shifter handle, will look into doing this myself instead of the dealer fix that will rebreak probaly.
Yup, that's why I did mine that way. I would have been covered under warranty too, but what's the point? A few bucks at Lowes and it has been working like a charm.
also just had this happen the other day getting off the trail in my friend's jeep, stuck in 4h, luckily it was on the transfer case side. we lined the cable end up with the shifter, then i just reached around the hot exhaust pipe (you can use it for leverage with your arm like i did if you want ) and slid the cable over the shifter and it held enough to allow him to shift into 2wd. just needed a little burn cream and away we went, got home and now need to fix it. thanx for the write up, we're gonna do this tomorrow.
What should the finished length of bushing be ? Is it same length od both T case and shifter side? Gonna make some up for me and my buddy.
Thanks for great post.
