Another mans shift linkage repair
#21
You know, I never thought to measure it before putting it in When I do the trans case side I will measure first........
Both ends LOOK to be the same, but I'm not positive.
#23
So, 2 weeks ago I was on the beach with my boys. After putting the JK back into 2wd, I noticed the wheel acting as if it were still in 4wd. Eventually, i was able to get it back in 2wd. Then today I went exploring a trail and then weh. I got back on the highway, it was acting like it was in 4hi still. I have shifted it back and forth between 4HI and 2HI over and over but the wheel is still acting like it is slightly engaged in 4HI. Does this sound like it could be caused by this same problem?
#26
Originally Posted by bgwright
Completely loose? Like, full movement along the track?
#28
Mine popped at the MOST inopportune time! I had just purchased my "new" 07 JK X from a stealership- it was at 2980 miles of the 3K warranty. It was the night of my bachelor party and already 9pm. One of my groomsman and I were rock climbing. As we tried to get out of a rut in 4low I tried shifting out and BOOM! It was stuck in neutral. My best man came and met us. After 45 minutes for the tow truck who was a total d^*>head we finally got her loaded I found out I was missing my wallet! I searched around the JK and groomsman ran back to where we were climbing. You could imagine my mindset already....it was around 10pm (bars closed at 2pm)...my wallet was MIA (meant no ID to get into bars) and my "new" JK was sitting on a flat bed..After my best man explaining my situation, the tow driver was apologetic and offering me advice. We crammed into his little yota and drank some homebrew while my wife came down an hour away to bring my spare ID card. Stealership fixed the bushing on warranty and paid for the tow and I got my lap dances with two hours of drinking to spare. Just thought I'd share how my bushing linkage nearly ruined my bachelor party.
#29
The issue isn't as bad as most people make it seem, a PITA yes but all you need to do is reach through the side of the console and put the cable back onto the lever and shift out of 4lo.This happened to me while in a parking lot. I now carry a 20pack of those grommets in my console. To fix it requires a allen wrench to remove the console cover. Either go fully modified with a zip tie or like the OP stated or replace with the regular OEM part.
#30
