Another mans shift linkage repair
#81
Just finished up my repair of this problem in the console. I started with a nylon bushing, drilled it out, trimmed the length, and shaved it down with a dremel tool to achieve the proper diameter. I added a hairpin clip to the end of the post. Hopefully if my modified bushing does fail, the hairpin clip with hold the linkage together.
#82
Former Vendor
#83
#84
anyone put these in? for 2007-current... Jeep Wrangler JK Transfer Case Bushings | eBay
#85
I completed the install of my new Rubi transfer case today and while I was in there, tore out the stock plastic bushings. I'm not sure if cross-posting is allowed on this forum so for the detail of the bushing I made and installed, here is a link to the post in my build thread with several photos of how I fit the bushing I made to the cable end.
I hope this's helps out!
https://www.jk-forum.com/forums/jk-s...6/#post4079484
#87
If you want to go with another material, I used a nylon spacer (see pictures). It works very well but I had to use a Dremmel tool to shave off about half of a millimeter from the outside of the nylon spacer so that it would fit in the cable eye.
Obviously, the original clip was not designed to last. I suspect that Jeep is not going to improve it either, since it's generating repair business for their dealers. Jeep is not known for it's quality or precision.
#88
I drilled out the black linkage eye to 1/2" with a step bit. Used a 1/2" screw cap and cut the tip off (used as a new bushing). Then used a cotter pin to hold everything together. There is a groove on the nipple that accepted it perfectly.
#89
shift arm lever instead of cable
Has anyone attempted to just attach a physical rod to the shifter lever on the transfer case and cut a hole in the floorboard and then put a handle on the end of the rod and shift the transfer case like transfer cases and transmission used to be shifted before engineers started overthinking things? I know it might take some creative design for the shift lever and a relocation of the floor penetration, but it would completely remove this nonsense with stupid cables that don't work when you need them to work.
I am dealing with this a 3rd (?) time and am in the slow process of ratting my 2010 rubi out anyways so I might try this. Have a fundamental problem with buying another cable that I know will fail at the most inopportune time for another $100ish or spending $200ish on a cable upgrade if I will be Breadtrucking the whole thing in a couple of years anyway.
Thoughts?
Thoughts?
#90
The little bushings are $3, why are you buying an entire cable? I also have a 2010 and while I've replaced the bushings twice now, I do have 220k miles and it's been on plenty of off-road trips and I've had the transmission down probably a half dozen times now.
