Did the grill mod today - Home Depot part #s and write-up
Old 04-24-2012, 03:51 PM
wuzzzer's Avatar
Boo. When I came home from work tonight I noticed that one of the grill sections has shifted. I definitely recommend to use some kind of adhesive in addition to the sticky tape that is on the mounting blocks.
Old 04-25-2012, 08:16 PM
ooltnun's Avatar
My home depot didn't have the gutter guards so I used some pet fencing.
It's galvanized steel sprayed metallic black with rustoleum. Looks sharp.
Old 04-25-2012, 08:22 PM
joncolecollett's Avatar
Like the red!!!
Old 04-26-2012, 03:37 AM
Cordur's Avatar
The red looks really sharp! Not for some red brake calipers?
Old 04-26-2012, 07:57 AM
TheDago's Avatar
I'm thinking about doing the red calibers sometime this summer. I originally wanted to fully black it out, but decided to go with something a little different.
Old 04-26-2012, 12:55 PM
wuzzzer's Avatar
Went to Wal-Mart last night and looked through their selection of glues. After a lot of debating I ended up selecting Loctite Stik'n Seal Extreme Conditions adhesive. I removed all the old mounting blocks and installed new ones. Put the Loctite in the shape of an X on the bottom of each mounting block. After doing that I put a bead of the Loctite on at least two sides of all of the mounting blocks until I had used the tube up. The grill is now sitting outside with the adhesive drying.
This type of Loctite is supposed to withstand temperatures of -58F to 248F. "Final bond withstands all conditions, both indoor and out" is printed on the back.
As soon as I have everything put back together I'll snap a few pics.
Old 04-26-2012, 03:54 PM
Milmilrx's Avatar
Really like the red. How did you cut the gutter guard? I think someone mentioned tin snips?
Old 04-26-2012, 03:56 PM
War Machine's Avatar
I actually cut mine with heavy duty scissors. It's not too difficult.
Old 04-26-2012, 04:03 PM
wuzzzer's Avatar
I used tin snips for mine. Wasn't too difficult.
Old 04-26-2012, 06:56 PM
jfleur91's Avatar
use gorilla glue and peel off the sticky piece on the zip tie blocks. I had to go back and fix my grill mod because the adhesive bottom part was NOT strong enough. Just giving everyone a heads up who plans on doing this.
Quick Reply: Did the grill mod today - Home Depot part #s and write-up
