Did the grill mod today - Home Depot part #s and write-up
#371
i did the gutter guard grill insert yesterday. Instead of using zip ties i put a bead of 3m weather strip adhesive around the inside edge of the entire opening. I pressed my insert down and held it in place for a couple of minutes then preceded to the next one. After the adhesive dried it held strong and firm. I think this is a better and more professional way to install instead of using zip ties. Just sounds kinda mickey mouse to me.
#374
I like that turned out nice....Might have to give that a try if I ever have to take mine off.
#375
Grill Mod on 2015 Rubi - First Mod EVER!
Just completed my first ever mod on my 2015 rubicon I purchased in December! Bought all the materials at Home Depot per the original write-up. Plasti-dipped the gutter guard. Not too sure how that is going to pan out over the long run. Worried about the rubber coating peeling off over time, but we shall have to wait and see. Only comment I have is about the 1"x1" harnesses. They don't sit flush against the grill in between the 7 iconic jeep slits. I had to use a lot of Gorilla Glue to keep them snug. Hopefully, the glue holds and they stay in place for a long while. Not sure if they sell 1/2" or 3/4" harnesses at HD, but I would try to search for something smaller than the 1". Overall, looks good and should be effective.
Let the mod addiction begin!
#376
Ran into the same problem with the zip tie connectors. Had to trim the sides a little to make them fit snug. Looks like you used enough glue. But if they come off, you may try trimming them down a bit.
#377
Crossing my fingers they don't come off for a while (is 6 months too greedy??) Good idea to trim the connecters. I will have to try that upon replacement. Thanks!
