The $1 Seat Belt Flap Fix
Old 06-03-2012, 06:24 PM
JK Jonesy's Avatar
Default The $1 Seat Belt Flap Fix
My local random dollar store had nylon dog collars for small dogs that can fit up to a 12" diameter. These collars work perfectly to help keep the seat belts from flapping with top down for both the front and the rear belts. Since there is a clip, they are easy to install and remove.
I will post some better pictures next time I have the top down.
This is what the collars look like
This is the collar on the front passenger belt
Another view of the front passenger belt. I should loosen the collar up a bit
Rear seat. I also need to clip off the leash rings.
Old 06-03-2012, 06:27 PM
4x4Play's Avatar
Nice. Great idea! I'll have to keep an eye out for cheap collars.
Old 06-03-2012, 06:31 PM
Emmeljk11's Avatar
I use the two Velcro straps that came with my jk. $$Free99
Old 06-03-2012, 06:40 PM
JK Jonesy's Avatar
If they came with your JK your were probably charged $20 for them! I was initially looking for velcro or some other sort of strap.
Old 06-04-2012, 12:49 AM
Quentin_T's Avatar
Yes the Velcro straps work, but they are also intended to secure the sunrider when flipped open. $1 doesn't seem like too much to spend here. I have found that on the drivers side, tucking it behind the small lever that reclines the seat works great, haven't bothered doing anything to the passenger side.
I will have to check these out.
Old 06-04-2012, 08:54 AM
Rooster76's Avatar
Default I found that a seatbelt sholder pad works much better
I put a strap around where you did for awhile with a small bungee cord. It worked better than nothing but would still flap from time to time by the belt feed.
I ended up getting 2 shoulder pads at wal-mart (made by "custom accessories"). They are about 8" long. I put them down by where the belt feeds out on each side, and it stopped the flapping cold. The custom accessory ones are nice because they let the belts spool back in. I tried another type from auto-zone that wouldn't let it go back in when you unhooked the seat-belt, so I returned those.
Old 06-04-2012, 10:16 AM
andre1002's Avatar
X2 , this works better than anything else ive tried.
Old 06-04-2012, 12:36 PM
MiJKguy's Avatar
Default velcro
fabric store $2 I got a couple strips of velcro and it works great, front driver I did the seatbelt padded thing! that flapping drivers me nuts!
Old 06-04-2012, 04:37 PM
Snowbrder086's Avatar
I'll have to pick those up!
Old 06-16-2012, 03:24 PM
nakednuns's Avatar
I bought a couple of black stretch arm bands for MP3 players off of flea bay for 5 bucks. These work AWESOME!
Quick Reply: The $1 Seat Belt Flap Fix
