Engine coolant 50/50?
Old 07-03-2015, 05:40 AM
Crushjk12's Avatar
Default Engine coolant 50/50?
I noticed the other day at 16,000 miles my engine coolant reservoir showed below the min. I went to the jeep dealership and bought the antifreeze/engine coolant. The guy said I didn't need to use 50% water and 50% antifreeze. However, all of the forums I found and websites say to use a 50/50 ratio. Thoughts?
Old 07-03-2015, 02:51 PM
karls10jk's Avatar
If your bottle says coolant then yes, mix it 50/50 when you add it in (distilled water obviously).
I don't recall seeing pre-mixed antifreeze at the dealer but I could be wrong.
Old 07-04-2015, 04:20 AM
webejeepin's Avatar
I did not see a pre mix at the dealer either, had to mix myself....you can adjust your ratio if needed..... 60 coolant / 50 water for areas that require that. I did 50/50 myself
Most important is to use the correct coolant type for your year!!!!!!
Old 07-04-2015, 08:24 PM
ronjenx's Avatar
Old 07-05-2015, 03:31 AM
webejeepin's Avatar
Originally Posted by ronjenx
One fellow I know through work is up in the High Arctic he was telling me a few tricks used up there to keep things from freezing.
Just tweaking the ratio a bit helps particularly one the nights you have to park outside.
Old 07-05-2015, 01:41 PM
ronjenx's Avatar
Yeah, I was just wondering how to mix a 60/50 ratio.
Quick Reply: Engine coolant 50/50?
