OR-FAB Sport Cage Installation
Only place it's different from a normal sport bar is the very front. So if you have door surrounds, no problem. If you just wrap the velcro around the normal cage, you would have to cut where it wraps around the handle I would imagine. I don't have one though.
Oh, and for the record, here are the rear streamer bars. They came today, but no powdercoat.
Also, here is the trim completed.
In one of the first pictures I saw you had installed a rocker switch in the dash panel on the driver side above the speaker, maybe for lights. Did you leave that switch in that location? I too have installed several switches there and with the side access gone because of the cage mount I was concerned if I need to get back to those switches for replacement or wiring repairs. Would it be best to relocate those? I am waiting for my cage still so your pictures were great.
Any additional wind noise or leaks in the soft top now? Did lowering your windshield cause any issues for chipped paint on the hinges or bolts that were removed?
Thanks
Thanks
I had a whistle right after putting the soft top up, but I was putting it down and up in 40 degree weather. Today I reseated it and no whistle.
Windshield doesn't cause any issues because the bolts are hex heads with rubber spacers. Of course, if you have hinge mounted lights, you have an extra step, and I wasn't expecting my hinge panel to fall off as I removed the last bolt. So I chipped it by dropping it, but not by removing it.
Door hinges you will chip paint as they are painted after installation. I'm probably going to take mine off again eventually to paint them with bedliner.
Your write up was very helpful. The install is a little more involved than I hoped but I am looking forward to working on mine when it comes in. I guess the unknown is part of purchasing a pre-sale product. I was told by an ex-OR Fab person that if there are rattles to tack weld the bolted pieces to solve that. Any rattles so far?
I must be waiting on mine since I ordered the gloss black. https://www.jk-forum.com/forums/imag.../z0tdntknw.gif
That was the thing that attracted me to this design. ***Disclaimer- this is my personal opinion** The fact that the design is just begging to be welded up or you have the option to leave the pieces bolted if you don't have the skill or the desire to go through the trouble of fitting, welding, removal, painting, and final install.
Sponsoring Manufacturer
Yates
