Heated washer fluid
Heated washer fluid
I added a piece of washer fluid line to my stock line so I could wrap it around the upper rad hose to heat the washer fluid. I believe it was a 6' piece of hose and 2 connectors.
Here's some pics of the final result.
It seems to work alot better with the warmer fluid. Cost less than 10$. I don't remember the hose id but they had 3 sizes and I believe I used the middle one.
COOL! Haven't seen that trick in years! (Did that in 1990 on my mustang and thought I was the shyzer ... until I melted my cowl LOL) Way cheaper than an inline "Hot Shot" heater.
sent by rinkish with a jitterbug
Btw the fluid doesn't get scalding hot. It warms it enough to.make it work better. I highly doubt anything will melt if anyone is worried. The spray pattern hits a lil more of the windshield also.
Nope. Not at all. Reason being alot of European cars have been doin this for a long time. I drive an excalade occasionly at work and it has heated fluid too.
It doesn't get hot enough to crack the glass. The other day I used it after Jeep was warmed up to remove ice on glass.
