Home Mod Sway bar disconnects
Old 10-01-2014, 08:25 AM
  #121
auceny's Avatar
Originally Posted by kh202
Definitely do NOT keep one side connected offroad
Thanks. I thought I read something hinting that you could but wanted to make sure. I have both sides modded now. 1/2" clevis pins, drilled out my stock links for 1/2", had to use a slightly thicker washer on one side to make it tighter.
Old 10-05-2014, 05:30 AM
  #122
Tooadvanced's Avatar
Originally Posted by wittys-jk
I have a question for some of you running with this set up, I have lost 2 sets of pins and bolts on the highway and I was wondering how common it is for the cotter pin to just fall out. It is normally a pain to get them on so it's baffling that they would just fall out. Just curious.
35k on this setup and no problems so far knock on wood
Old 11-13-2014, 07:43 PM
  #123
nmjeepster's Avatar
Did this last weekend I used a 1/2-3 and grindded down the pin so it's a tight fit in the bolt hole
Old 11-13-2014, 08:01 PM
  #124
Mad Dog 21's Avatar
What did you use to grind it down and did you drill out your sway bar links too? I'm want to keep everything stock right now. I would like to mod the pin to work with out drilling out my swaybar link holes.
Old 11-18-2014, 08:08 AM
  #125
parnecr's Avatar
Couldn't you just do the same thing with a metric bolt (same size as stock) and drill for the retaining pin? That way no extra mods to links etc. are necessary and tightness is same as stock.
Quick Reply: Home Mod Sway bar disconnects
