How to change your spark plugs
Ya the angles are terrible especially when you are leaning over the front fenders. I am 6 foot and i had to get a box to stand on so I could reach my arm down there.
Here's a quick breakdown of spark plug analysis:
h++p://www.gnttype.org/techarea/engine/plugs.html
Yeah I got that on my new ones for sure.
Spark Plugs I bought: NGK (4998) PLZTR5A-13 Double Platinum Spark Plug
New Next to old ones:
Here is a picture of my old ones in order of how they came out. I see people posting sometimes about information on how the look with the cylinder or whatnot. So anyone with information fire away!
The Upper Right one(right row) and the Second one(middle) on the Left row look in better shape than the other plugs.
FWIW - Silver plugs already come with an anti-seize coating.
Black plugs are ones that could/would benefit from anti-seize. (Per NGK documentation).
Personally, I'm against anti-seize on plugs. I've done it in the past, and it coked up on the threads making removal harder. BMW warns against using anti-seize stating that it can cause poor grounding between the plug and head.
The subject of using anti-seize on spark plugs has good and bad points on both sides.
I use stuff designed for spark plus, applied sparingly on the threads.
I use it because I've never had a problem with it, and have had problems without it.
This is from the 2008 Factory Service Manual regarding spark plug installation:
1. Coat threads of spark plug with anti-seize. Be sure not to get anti-seize ANYWHERE BUT ON THE THREADS OF THE SPARK PLUG..
2. To avoid cross threading, start the spark plug into the cylinder head by hand.
3. Tighten spark plugs by referring to the Torque Specifications chart. [12 ft./lbs.]
4. Install spark plug cables over spark plugs. A click will be heard and felt when the cable properly attaches to the spark plug.
The instructions above state to "coat" the threads with anti-seize. I can't imagine that means to gob it on, so I apply it sparingly.
Since the manual expects anti-seize to be used, the torque specification takes that into consideration.
Thanks for the write up and all the comments, I changed my plugs this weekend. No problems and there was a noticeable difference in the jeeps sound and power.
Jeep is at 60,000 miles.
I got a set of Crown wires from Quadratec at a reasonable price. I figured I might as well replace them while I have everything torn apart. The hardest part is routing 1,3, and 5 behind the engine but even that's not too difficult.
Just a quick helper. One, use a piece of tubeing over the end of the plug to help start it before using the wrench on it. Like vacuum tubeing works well, and a tight fit, helps you start it in the threads.. Two, I use a board, 1/2 x 6" and lay it across the rad. and cowl to lay on and work over the engine, plugs are better from the side though.....
