How to replace the Clock Spring
How-Tos on this Topic Last edited by IB Advertising; 12-22-2015 at 02:44 PM.
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Results 1 to 6 of 6
  1. #1
    JK Newbie hunty's Avatar
    Join Date
    Apr 2009
    Location
    Sydney, OZ - Australia
    Posts
    87
    Default How to replace the Clock Spring
    Cruise control not working?
    Airbag light and chime driving you crazy?
    You most likely have a worn / broken clock spring!
    Step 1
    Buy a new CS from Amazon, Ebay or wherever. I got mine from Amazon for fraction of Jeep AU price.
    Step 2
    Straighten the steering wheel.
    Disconnect the battery, I did because I absolutely did not want to accidentally set off the airbag - didnt fancy a screwdriver in my forehead, some may say it would be an improvement LoL
    The only tools you will need are
    a long T20 torx driver,
    philips head screw driver
    bend yourself a special flat blade screw driver
    Socket, ext and driver - to loosen the nut behind the wheel - Not the Jeep enthusiast LoL
    Step 3
    Remove the plastic panels around the steering column by removing the 3x T20 screws (underneath the wheel, 1 is silver and visible and 2 black ones are hidden)
    Step 4
    Remove the Horn button / Drivers airbag
    by using the bent screwdriver to gently pry / lever off the cast steering wheel hub 3x U shaped spring clips (they remain attached to the Airbag / Horn - when you spring the 3rd one be ready to catch the Airbag / horn and unplug it.
    Step 5
    Disconnect the white plug at TDC and remove the centre bolt that holds the steering wheel. Pull the wheel off - I didnt use a puller (some say I have expert pulling skills) just a big grunt LoL
    Step 6
    Remove the blinker stalk by removing 1x Philips head screw (on the left side) and unplug it.
    Step 7
    Remove the Headlight stalk, 1 x Philips screw (on the right side) and unplug.
    Step 8
    Remove all the plugs from the old CS.
    Step 9
    Remove the 2 silver torx behind the old CS and 1 silver torx screw near the IGnition Key Hole and gently pull off the old Clock Spring.
    Step 10
    Replace CS with new one - leave the yellow CS lock in place until you have put the steering wheel back on and tightened the centre bolt.
    I hope you guys find this useful and it saves you some cash
    cheers Hunty
  2. #2
    Join Date
    Apr 2009
    Location
    Posts
    87
    Smile inside the clock spring
    The clock spring is a stupid name for a device who's sole job is to connect the buttons and controls on the steering wheel that rotate around during normal steering wheel operation, the horn, stereo, blinkers , lights airbag etc all need to be connected and working whilst you saw on the steering wheel, the device itself looks a bit light a spring you might find in an old clock.
    In a JK it has one more significant function i.e
    It continually measures the angle of the steering wheel and feeds this info to the ERM and ESP computer - in the case of ERM, the computer knows what ratio the front wheels should be turning at based on how much you turn the wheel and if this even varies a small amount you get the brakes on esp light on and throttle cut
    You can see the awesome attention to detail Jeep has gone to - they are using a light breaking beam detector on a perforated ring and a potentiometer to give them maximum knowledge of where the wheel is and how fast it is being turned.
    hope you enjoy the pix cheers Hunty
    ar
  3. #3
    Join Date
    Apr 2009
    Location
    Posts
    87
    Smile Nude shaft
  4. #4
    JK Super Freak SBEII's Avatar
    Join Date
    Jul 2010
    Location
    Myrtle Beach, SC
    Posts
    1,975
    Nice write up. Mines already been replaced under warranty once. I guess I better study up.
    Mr. 2011 Red Rubicon JKU
    Expedition One Basix DX, Warn M8000, RR QD mirrors, Congo Cage, Teraflex Performance leveling kit, 35x12.50 BFG KM2, 1.5" Spidertrax spacers
  5. #5
    Join Date
    Apr 2009
    Location
    Posts
    87
    Smile CLock spring x3
    Quote Originally Posted by SBEII View Post
    My Jeep has also had 1 under warranty and 1 I just replaced one so MY 07 JK is on its third D'0h.
    cheers Hunty
  6. #6
    JK Newbie Hvacwelder's Avatar
    Join Date
    Dec 2010
    Location
    Rock Hill, SC
    Posts
    76
    I noticed the recall is for the "Right Hand" drive models. Anyone report the left to be affected? Must be a big issue as it's reported on 2 different dates on the NHTSB site.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
