Jeep JK 3rd Row Seat Write Up
Old 02-26-2012, 08:09 PM
JKU2007's Avatar
Default Jeep JK 3rd Row Seat Write Up
I finally got around to adding my 3rd row seats in my JK. It took about an hour and a half start to finish.I started by pulling all the carpet up in the back & used bungee cords to hold it back. I then laid the brackets down in the approx. location that they were suppose to be mounted.
Next I positioned the brackets using the measurement provided in the directions, & market where the holes needed to be drilled using a silver sharpie. (Very important to make sure the brackets are exactly squared)
I then used a hole punch to start the holes before I drilled them to make sure the holes were drilled on center.
Then using a small bit I pre drilled the holes, then went up in size to get the holes drilled to the correct size.
I then sprayed rustolem on the holes to try & prevent any rusting.
The kit included Nutserts to install the brackets, but I didn't feel safe doing that so I went out & bought some Bolts, Nuts & washers & used those to mount the brackets to the bed in the jeep. It did require 2 people since one needed to be in the jeep & one needed to be under the jeep to tighten the bolts/nuts. The measurements on the directions were spot on & the bolts all mounted easily.
Next I started putting the carpet back down.
After laying the carpet down I had to take a razor & cut slits in the carpet for the brackets to stick through. I also had to cut down the rear storage panel to allow it to open/close with the new brackets in place.
I then put the 6 bolts into the brackets & added the rear seat. Thats all it was too it.
Old 02-26-2012, 09:09 PM
Bohemoth's Avatar
Post
Who made the brackets? I'm not sure how much I would trust the rear seat to stay put in an accident with it mounted to only sheet metal.... Looks like an easy enough install though.
Old 02-27-2012, 03:23 AM
JKU2007's Avatar
Teraflex. It uses a 2 door rear seat
Old 05-31-2012, 11:48 AM
Chesterhull's Avatar
Great write up!
What length/size bolts did you go with?
Anything special?
Old 07-09-2012, 12:19 AM
JKU2007's Avatar
Originally Posted by Chesterhull
Great write up!
Anything special?
All the bolts were included with the mounting bracket.
Old 07-10-2012, 03:17 PM
spartan99's Avatar
This setup is much nicer than mine. Very nice.
Old 08-26-2012, 07:20 PM
JKU2007's Avatar
Thanks. It works great
Old 12-29-2013, 09:54 AM
Blank1984's Avatar
Looks great! Give us an update! What's your seatbelt solution?
Old 12-29-2013, 10:31 AM
SKTN Rubi's Avatar
What are those brackets worth? There is an 07' rear seat on kijiji close by for 100$. Just seeing what my total cost would be. Thanks.
Old 01-01-2014, 07:55 AM
Blank1984's Avatar
In 0.163 seconds, I found that Teraflex still has them... "Google" teraflex 3rd row seat
If you need help finding the price, let me know.
Quick Reply: Jeep JK 3rd Row Seat Write Up
